SomeFReaK
Oct 4 2002, 11:13 AM
Hi All,
I am currently looking for a high powered monoblock to run in my spl setup, it the moment i am going to be running a single woofer setup. I have been doing my rounds looking at amps and so far i have come up with:
Earthqauke phd2
JL 1.1000
Lanzar 2000D
Is there any other amps (upto around $1500 in value) that i should look at?
What do people think is the pick of the bunch and why?
SomeFReaK
2001 Hyundai Accent GS
Soon to be Hyundai Accent GS-t
Currently listening to - Soundtrack from xXx
http://freakcentral.devgeeks.org
Accent forums online http://forums.devgeeks.org
My Band (Weezal) http://www.weezal.com
BIGW
Oct 4 2002, 03:18 PM
x fire bmf
mtx 81000d
dls d1000
signat dig 1
out of the ones you chose id wuld lean toward the d2 as they can be burped after beign modded slightly to run extremely low loads and will do more than the rated 2kw @ lower loads
jon
hu: kenwood 9018
Front stage: 3-way Dls Magnesiums 6.5" with ultimate tweeters and dynaudio 9.5"
subs: Wall housing 2 x DLS sp12 d2
Amps f/s: Valve Audio class A 4 x 100 rear 2 ch running dyns
Sub stage Amp:2x Valve Audio twin monoblocks 3kwea
Power: 5 x yellow tops, 180amp alt
visual: kenwood 8" widescreen, xbox enigma 5.6" tft
Team Gates
Supporter of CAA SPL Project
The Scribe
Oct 5 2002, 03:40 PM
Havent heard a great deal about the Lanzar, but out of the others, I would go for the d2...
CAR: 1994 Dark Blue/Purple VR Commodore (Stock as hell!)
DRIVER: One 6'6" Lanky Wigga
AUDIO GEAR: Pioneer // JL Audio // JVC // Stinger
MORE GEAR TO COME: Sub Amp // Sound-Deadening // Neons // Alarm
NEXT A.C.T. CAR AUDIO AUSTRALIA MEET: Meet up on Oct. 13th and cruise to Syndicate sound-off (Refer to topic in Events, Shows and Meetings' forum)
Andu
Oct 5 2002, 04:48 PM
Lanzar's are cheap as chips though. picked mine up for $850 second hand. 1800wrms@1ohm... daily driven at 1ohm, doesn't get warm at all.
Car: '90 Nissan Pintara (sedan)
Headunit: JVC KD-SX750
Fronts: TotalRecoil Carsplit.6
Frontamp: Alpine MRV-T301
Sub: 2x Alpine SWR-1240D
Subamp: Lanzar VPro 2000D
SPL: 145.4db (Doran Test Day - 29/09/02)
"If its not quick, may aswell make it slower"
ripped
Oct 5 2002, 05:27 PM
D2 power wise will win. are you going to be using the piston? the d2 will be fine for 2ohms.
2002 Holden Astra
HU: Blaupunkt Miami Beach
Front Stage: Orion XTR 6.2
Front Amp: PPI 2360 2x90
Subs: 2 x Audiobahn 1200Q
Sub Amp: JBL 1200.1
Dead Last at Drag Combat 2-3 Woofer class
Winner at BAS 161-260sq inch.
ripped
Oct 5 2002, 05:33 PM
andu, how much in fuses does your lanzar amp have?
2002 Holden Astra
Sub Amp: JBL 1200.1
Clarkie
Oct 5 2002, 06:12 PM
Lanzar 2000d has 4x 30 amp fuses,I'm pretty sure they are unregulatered so need a strong 14volts to make there power.They sell for $249us on several sites in the states which is a bargin if your mate can bring it back or you live there.Out of the 3 you listed D2 handsdown.
Clarkie
NZ Record
st 1-2
150.7db
K/wood 12"DVC(x2)
K/wood D class
[Edited 1 time by Clarkie on 05 October 2002 at 16:14]
Oct 5 2002, 06:19 PM
quote:
remember, that for a given heatsink size (and efficency), and amplifier efficiency (most D class amps are of similar efficiency) the amp which is hotter is generally putting out more power
- A proud member of Team Gates - A proud supporter of the CAA SPL project[Edited 1 time by Bassaholic on 05 October 2002 at 16:22]
ripped
Oct 6 2002, 08:28 AM
i am no maths genius....
120A*14.4V*100%eff.=1728watts
i don't see how the lanzar puts out 1800w even at 100% eff. my JBL also has 120A fuses, and it's rated at 1200wrms, so maybe that is a more realistic power output.
get the D2, more power.
2002 Holden Astra
Sub Amp: JBL 1200.1
Andu
Oct 6 2002, 12:00 PM
The JBL 1200.1 will put out 1200wrms@2ohm and the D2 1600wrms@2ohm whereas the Lanzar only puts out around 1000wrms@2ohm (unsure of the exact figure, I only remember its not very impressive)... Anyone wanna donate me some dual 2ohm subs so I can load down my amp
"If its not quick, may aswell make it slower"[Edited 1 time by Andu on 06 October 2002 at 10:01]
markjh27
Oct 6 2002, 01:19 PM
I have a 200DHC Earthquake Digital, and it's rated at 2000WRMS at 2ohms, how come u said it was only 1600WRMS? Cos i am frigged if it is, as i was told by a reputal company when i bought it that it was 200WRMS at 2ohms!
Mark
Ignite
Oct 6 2002, 04:03 PM
Get the D2 Tim
Im biased tho
/me checks signature
Laterz,
Anthony
n15 pulsar plus 1.6l
source - /////Alpine CDA-7894RB
fronts - /////Alpine DDC-R17A Split
rumblers - 2 x 15" Hi-Fonics Zeus Subwoofers
makes rumblers rumble - Earthquake PHD2
makes fronts front - Kicker ZR240
Member of Team /////Alpine
PROUD Member of Team Gates
145.0dB @ 48hz and still rising
the[K]id
Oct 6 2002, 06:27 PM
Concept D2400A
Good part is you can get lots of power at 0.5Ohm if your using a 12V (normal car batts) setup. Just remember they can draw up to 200 amps (like any 2kw+ amp will).
Oh, and there might be one or two available for around 1500.
Weaponx: "Im starting up a new team, its team "Craig David" "
bluemini: "weapon, have you been in to daddies medicine cabinet today??"
Cyberpunky: "forget the specs, and just listen to what is watt"
Ali G: "Let's increase da peace, and keep it real"
Team Digital-Is-A-Marketing-Gimic Member
Team Tycoon - Dollers n dB's
Team Gates - teamgates.org
SomeFReaK
Oct 7 2002, 11:13 AM
I know the JL amp has a regulated powersupply, but do any of the others (like the d2, my current favorite)
SomeFReaK
SomeFReaK
Oct 7 2002, 11:14 AM
Oh and ripped, probably either the red or the piston, gonna do some testing
SomeFReaK
Tarwahh
Oct 7 2002, 12:37 PM
quote:
The D2 & Lanzar both have unregulated power supplies. I emailed Lanzar and they said the 2000D is good for up to 16V
DVC 12" Alpine Type-R that lives in Andu's car hehe
ripped
Oct 7 2002, 03:39 PM
tim, when you go testing at bassdemon's house, get my 8" tornado back for me. my cousin wants it back now
remember, no tornado, no amp for the comp this weekend
2002 Holden Astra
Sub Amp: JBL 1200.1
ripped
Oct 7 2002, 03:42 PM
by the way, if any of you guys with these monster amps want a better comparision between the amps at 1ohm, 2ohm, or 4ohm, mail them up to me and i'll do some spl testing with them in my setup
2002 Holden Astra
Sub Amp: JBL 1200.1
