Full Version: SEPERATE CHAMBERS OR Single CHAMBER
fiGJAM
I doing my self a boot install and I have had many people tell me contradicting things.
I need to know the ADVANTAGES/DISADVANTAGE or possibilities of having a box for 2 * 12" Crossfire BMF's in a box with Seperate chambers and also ONE BIG common chamber?
Please help
I am after a system with good mix of SPL and SQ.
Regards
Aaron Glover
(Newcastle)
Crossfire BMF 1000D @ 1 ohm
2 x 12" Crossfire BMF 12D's
Crossfire TEK 75.2 Amp
Blaupunkt Overdrive ODca650 6 1/2" Splits
Pioneer DEH-6450 CD Tuner
http://www.caraudioaustralia.com/ubb/Forum...TML/007687.html
SPL KINGS 2001
161.0dB Amateur Record, set BAS 2000
153.4dB Loudest Sedan
158.5dB Loudest SS 1-2 (single DD 9515)
160.8dB Loudest SS 3-4
166.2dB Loudest to Date
TEAM DD
icebreaker
Well from abit of playing i've done, i won't be bothering with single chamber again.
seperate chamber per sub, much more precise for tuning, and driving.
As a shared chamber obviously opens you up to varying factors. Duplicating power to both subs, calculating air capacity, due to both woofers affecting air pressure of the enclusure during use.
But if your install dictates that you can't chamber the subs seperately, then you'll have to do, what you have to do... And share them...
my 2c.
audison »»»morel Clarion{Image Dynamicsz PPI OPTIMA Stinger
Proud Member of: Team CAA | Team Gates | Team Image Dynamics | Team G-Spot
CAA Extreme Car... It's not an idea, It's a Reality...
fiGJAM
I think I like the idea of having seperate chambers. My install can have a wall in it. just that the guy who is doing it is trying his best to recommend doing it in ONE chamber.
I have been told by several people to definately put them in seperate chambers, one of those people being Tony Doran from Doran Pro Audio and I think I will take in his advice as he seems as though he knows **** about car audio.
Thanks for all your comments guys.
Aaron Glover
(Newcastle)
AUII FORD Falcon Futura
Best SPL Score 142.8DB
[Edited 1 time by icebreaker on 01 October 2002 at 08:13]
basspimp
if you're running both subs of the same channel then it wouldn't make much of difference, but stereo would be a different matter because if one subs fails then the other will immediately see more volume and become severly unloaded. maybe it's safer for seperate chambers over a common chamber if you're planning on giving the drivers a gut full!
Pimpin' ain't easy!
