I blew the 20A fuse on the speaker outputs yesterday (finally did some decent testing). I've never felt my amp so hot, and that was before I rewired it into all-parallel!
Running 3 DVC (3ohm/coil) Magma12's - ALL in parallel
First I did testing in street mode - coils from one sub in series, then all subs in parallel to get 1.5ohms to amp. All in parallel worked out to be like 0.0975 ohms or something
I also have 10A fuse (external) for each sub (whether coils in parallel or series).
Ok so I wanna know two things:
1. How safe is it to put in a 30A fuse inside the amp (as indicated on the PCB in the amp)? I know Weapon's done something like this, but I can't afford to repair the amp in time for FB if I blow it up. Fuses are cheap and quick & easy to replace.
2. Can I actually calculate impedance?? I know there is software out there, but I wondered if it was possible without a cro and do it all on paper/calculator... I forgot that you need a tong-ammeter to be able to measure AC current (me being an electrician and all
) and just had my trusty DMM. I measured the speaker-output voltage of the amp and I didn't get to measure too high when all coils were in parallel
I found the real reason my amp seems like it's "reducing power" - a problem I've noticed over the last year or so during SPL comps and testing days... It actually is due to less volts. Almost flattened the dual Odyssey's while testing - twice - and in under half an hour, to the point where I decided to leave the engine running. Engine-off testing I was getting 2v voltage drop (coils series/parallel connected) before amp started to complain
My handheld SPL meter must be way out of calibration - I could only manage a best of 106db(A). Went off the scale in db© though (understandibly).
I will try and borrow a cro from work but I wont have any chance to pick it up before the end of next week.
Third question: Is anyone able to lend me their's and bugger I'm going to need somewhere to do the testing as I wont want to do it at my place!!! I usually drive to a remote area to do my full-volume testing.
Rich.
CarAudioAustralia NSW Representative.
2nd: Street 1-2 @ Sydney Auto Salon - June 2001, 1st: Street 1-2 @ Supernats - Sept 2001, 1st: Street 1-2 @ Auto Salon Final Battle - Nov 2001, 3rd: Street 3-4 @ Sydney Auto Salon - May 2002. 145.2dB @ 39Hz on DORAN's SPL meter!
-99 Pulsar SSS with dual Odyssey1000's, Lightning Audio Monitor cap, Alpine TDA-7572R & CHA-S624 & PXA-H600 & MRV-F505, Orion XTR5.2 & XTR8MB. Weapons of choice: Earthquake 200-DHC now running THREE!!! Magma12s in ported common enclosure currently tuned to 45Hz for SPL. DailyDriver: ported JL12W0 running off a Schneider amp in a Hiace-
"Standing by the stereo I'm feeling so alone, My back against the speaker and I'm moving on my own, Surrounded by so many and they're staring at my face, They're picking up my problem - I'm totally addicted to bass!" Image is Nothing. Imaging is Everything. click [email="basshead@blue-lagoon.com.au"]THIS[/email] to email me directly!
[Edited 1 time by basshead on 08 October 2002 at 23:55]
