Let's say I get a sub rated at 100wrms, so I get an amp at 100wrms, thereotically it will be as efficient as possible, hence maximum SPL from it, correct?
now, say you by a 1000wrms sub, you will then need a amp at 1000wrms, and again it will be operating at max efficiency, but will the SPL higher?
If not, thereotically you could just get a high excursion 1wrms sub and amp. (if the power is only for a cleaner signal (which I think it is
) then you just spend mega bucks on a extremely clean signal and just have a simple 1 wrms amp and sub.in the words of Austin Powers "oh no, I've gone cross eyed."
System Includes: /////Alpine, Rockford Fosgate, Boss, more RF - see pics for info
----====124dB=====----
My Pics
BASS ON BOARD.
If something can go wrong, then it will go wrong
Team Xmax - Xtend your surroundings
Our Scores: 1st - 135.9dB from V-net 10"
but its good for marketing purposes and for bragging to your mates. it has nothing to do with how loud the speaker is or can go. all it tells you is how much amplifier power the speaker will take, without blowing up. so, a 500 watt sub will not be louder than a 200 watt sub, just because of the rating. it has to do with the speakers design, its enclosure, the amount of power you feed it, how it is oriented etc.
