ripped
Nov 14 2002, 03:39 PM
how many times? what model(s)? what impedance(s)? how many burps, how long were the tones etc? i just want to know all the details, mainly cos i want to know what i am in for...
and were the amp(s) modded, and if so what way...?
[ November 14, 2002, 13:40: Message edited by: rippedskin ]
Purps smoked one of his d2s @ 1 ohm i think. the normal mod of upping the internal fuse i think it is.
d2s are funny alot of people have smoked then and alot have had no problems. all at the same ohm etc
Smoked mine once, after a comp, little volume and at 1 ohm.
Bodyjar
Nov 14 2002, 03:54 PM
I wanna know aswell! And how exactly do they smoke? what burns, how much to replace etc etc...
And I thought the mod was adding 2 extra caps? not changing the fuse?
ripped
Nov 14 2002, 04:20 PM
yeh, there are a few mods out for these amps...
hmm, so the d2 doesn't like 1ohm. hmm
there are quiet a few. Internal fusing, change a couple of caps, and a big one to make it more on par with the d3
Bubba
Nov 14 2002, 04:48 PM
we blew a d2 we blew all the fets and all the resistors that was $190 to get fixt and we blew sumthink else that makes the amp run witch hasnt been fixt yet that'll probely be a nuther $200 so dont go blowing these amps
oh and we blew the amp at .7 of a ohm arfter about 15seconds of burping at 50 hz
[ November 14, 2002, 14:49: Message edited by: Bubba ]
ripped
Nov 14 2002, 04:54 PM
damn, 15sec... what the hell were you trying to prove ???
Nov 14 2002, 05:03 PM
one of the mods (proper mods, not the fuse change) helps it put out more power at higher impedances.. it will make it more likely to fry at lower impedances..
[ November 14, 2002, 15:04: Message edited by: Bassaholic ]
Bodyjar
Nov 14 2002, 05:14 PM
Ripped: find out what mod has been done to our amps! I thought you said it made it more stable at 1ohm?
ripped
Nov 14 2002, 05:26 PM
krase: do you know what mods were done to make the d2 perform like a stock d3?
i don't know how to do it only know of amps that have been done
pig75
Nov 14 2002, 10:21 PM
ok first one my old 200DHC got half way through a song fried both subs which took the amp out 2ohm
got the amp back tried 1ohm smoke
got it back again run it at 4ohm got to the second last round & run it at 1 ohm smoke .5 sec
then got a d2 run it at 1 ohm smoke 1.5 sec
then got a 200DHC MK2 did not even get to hook it up to the subs - speaker out touched the body of the car smoke
have seen them go up in smoke just hooking up the power wires
have never modded a amp
have run them at .75 and no smoke it all depends on the subs and box
each time it cost between $180 & $250
it's all good fun
yup the key is to find the inpedance rise of the box
[ November 14, 2002, 20:51: Message edited by: KraSE ]
PuRpS
Nov 15 2002, 12:27 AM
pig were bouts did u get ur amps fixt?
ripped
Nov 16 2002, 02:26 AM
ok, assuming i get warrantty, i can smoke away and EQ will fix it under its warantty right?
of course i'll say, i was only running it at 2ohms... so is it ok for me to smoke away and not get charge for the repair???
i hope there are no EQ reps on this forum
PuRpS
Nov 15 2002, 03:09 PM
we blew all the fets and resistors and 1 or 2 IC's
if u cook the ICs the amp mite aswell be chucked in the bin because there is no modle/product number on them so u cant get replacments
**** happens likes a *****
if your not braking **** u arnt trying harn nuf
ps it was at a nominal .5ohm (real world was about .7)
luv my PHD2 wouldnt mind a few more
ripped
Nov 15 2002, 04:09 PM
you should have been expecting smoke at .5ohms... plus playing tone for 15sec is just asking for trouble.
hope mine doesn't blow up
yutryn
Nov 15 2002, 06:12 PM
can anyone tell me of a website or person or something that explains the mods and how to do them
any help greatly appreciated
Andu
Nov 15 2002, 07:28 PM
200DHC Mk1
2ohm load.
Bought it then as soon as I turned it on... volume turned down to nothing.... heard some crackles, car filled up with smoke. wooohhoooo!
If the images didn't work they can be seen here:
http://www.picturetrail.com/gallery/view?p...6451&uid=672718
ripped
Nov 15 2002, 08:53 PM
ok, i assume you bought a dud andu
Andu
Nov 15 2002, 09:05 PM
quote:
Originally posted by rippedskin:
[b]ok, i assume you bought a dud andu
pig75
Nov 15 2002, 10:59 PM
A/Z with the first
then eastern car sound
we also have the schmatics for the D2 witch shows all the chip numbers
PuRpS
Nov 17 2002, 02:22 AM
does that mean u would ahve the part numbers for the IC's ???
cannon
Nov 16 2002, 06:17 PM
correct me if im wrong but i belive that the d2s are designed to run at 1.3 ohms dont get me wrong they run at 1ohm but eventually something has to go it happend to a mate and had his for about 2 years at 1ohm without a problem and then out came the smoke he blew a capacitor
ripped
Nov 16 2002, 07:25 PM
they are designed to be stable at 2ohms... but people burp them way below that level.
Nov 16 2002, 07:36 PM
yes, they are designed for a 2 ohm nominal load for daily driving..
pig75
Nov 16 2002, 08:18 PM
yep
ripped
Nov 17 2002, 12:30 PM
Originally posted by pig75:
[b]does that mean u would ahve the part numbers for the IC's ???
yep [/b]
good, when i smoke mine you can fix it for me then
WeaponX
Nov 23 2002, 09:47 PM
I had the DHC 200 for a year, ran it at 2 ohms nominal no problem,
Ive had a few D2's and Ive blown a lot more subs than amps with these things.
I ran two at 1 ohm unmodded for daily driving for around three months and one eventually blew, they would get very hot at the lower impedances at high output levels, when it blew I had been playing it at 1 ohm at almost full volume for over a half hour cruising and it was red-hot when I checked it.
I then ran four modded extra caps at 1.3 ohms Re for six months daily driving with a 120mm 12V fan on each one and they loved it , the cooling fans made them a lot happier, they never got hot at all, best $80 I ever spent on those four fans.
Luck of the draw really, IMO going under 1 ohm on the D2 is really rolling those dice, its kinda fun actually.
I was present (and probably partially responsible) when we blew one of Purp's, but sheeat happens in the heat of the SPL run when you are always looking for a bit more performance..
SUBWRX
Nov 24 2002, 09:43 PM
hey u said u had the scematic diagram for the d2? can u tell me where u go this or woulf u be able to give me a copy, i would be willing to even buy from u as i can fix them my self with these diagrams, i can just never locate them.
ripped
Nov 25 2002, 04:05 PM
pm pig75
