Feb 12 2003, 09:39 PM
Which of these categories do you see having the higher scores?
Ok with two 15's and two 2 channel amps. Wat category would i be in?
If i put a battery larger than the stock location would this put me into super street 1-2
there is no street 1-2 anymore
street A and street B
2 15"s would be street B
hardon
Feb 12 2003, 09:57 PM
The problem with street B is that u can't run your engine, whereas in SStreet u can, but u risk competing against guys with bigger subs and more extreme setups.
I totally up in arms about what to do with my system - the enclosure is above the door line by about 2 inches, so it's not classed in the NO WALL class which sux. And the enclosre forces the removal of back seats so it's definately not street.
I'm kinda stuck between a rock and a hard place......
wall wall wall wall wall WALL
heheh
[ February 12, 2003, 20:10: Message edited by: KraSE ]
Feb 12 2003, 10:23 PM
i never said street 1-2.. I said Super street 1-2. this is two 15's two amps, altenrator upgraded, and running.. with 2 batteries allowed.
In street B its pretty much new battery and two 15's and two amps..
Super street aint much difference.. I can then make a box fill the boto anc back seat of an excel...
14cubic feet for two 15's tuned at 40hz should go quite loud
im so lost what will i be in ... single 15 or 12 with one 1 x 2 channle amp .. with no bat or alt upgrade .... not a wall
street a ???
street b ??? and what's thie ... with out my car running ...... that's only like 12 volt ... that's gay
sorry .
well in SS u will be against cars with walls. ss1-2 n/w u have to keep being the b pillar and below the window line, not the biggest box.
ss1-2 numbers r around 160 atm
ss1-2nw numbers r around 155 atm
Feb 13 2003, 01:24 AM
It could also depend on the subs/car.. If you can't get enough box volume without removing the rear seats, then you'd really have to go for SS no-wall
ripped
Feb 13 2003, 02:53 AM
maz,
what are you asking again? what class will have higher scores... Street B vs ss1-2...
um, super street will have higher scores... because of the following:
1. more amps
2. higher voltage
3. bigger subs
Feb 13 2003, 05:53 PM
when it was street 3-4 and street 1-2 last year, 1-2 had scores nearly as high as 3-4. Mainly due to lack of competitors
hardon
Feb 13 2003, 08:13 PM
Kraze, maybe one of Bones WICKED ONE enclosures for two 18's might be the go for SS NW???!!!
ripped
Feb 14 2003, 02:54 AM
yes, but you are now comparing street class VS SUPER street class...
super street, has unlimited amps and batteries you know...
