Full Version: setting amp's... Eq's and HU setting's
DD
HOW TO DO ALL THAT FOR SPL ?
ripped
i thought you would know by now. it doesn't really matter what the settings are, as long as you know ehn the signal is clipped and as long as you know that you are getting the full power out of the amp you'll be right.
we put a scope on your amp last time, it should already be set.
DD
im only useing the EQ to get the volt up to my amp as it put's out a 7 volt's to my amp ...hehehe ...... s does not MTTER WHAT the HU is set on or the EQ or the amp gain ?
ripped
if you bypass your EQ you might find that you would pick up SPL.
DD
but then i will loss volt to my amp ..... ?
Bodyjar
I dont think your amp would benefit from 7volts anyways... especially for SPL...
Bypass it if you can.
DD
oh k then for this comp i will NOT use the EQ.. but will also need help working out HU volume and HU sub level and amp gain ?
ripped
max everything but the hu volume. start at half volume and work your way up until the SPL drops.
DD
or max all setting and put it on a scope ? is that the same thing ?
