Just want to know if any one has used the 3512,s in all out s.p.l set ups?Have run one in a 3cuft(gross)box on sat at comp and want to know if it well responed better in a 6cuft box.Vehicle is a suzuki alto so has small cabin res/freq is 62Hz I have one amp on it approx 1300-1400rms at full power.I have a 6 cuft box which I can mod to fit DD very easy.could probley reduce volume in box(say 4.5cuft if you thought 6 is to much).Normaly I would test over a few weeks but biggest comp in south island is next sat (6 days),have 2 cars to sort out also.
Did 142db flat on B+K PCRTA(Approx 147db on termpro)battery voltage drops to 13.8v at full tilt so should still make good power(Amp).
Car was set up to run 4 subs but no product has turned up from my sponser.I put the DD in a box that was made for my kenwoods covered the port with a stainless bowl and made up a port on thursday night(not tuned)
Can anyone shead some light on the box size issue,want do ya think Phil??
Cheers Shane(Clarkie)
http://www.canze.org.nz/forum/messageview....d=5724&start=41
Two pics on my sig as above.
[ March 23, 2003, 20:39: Message edited by: Clarkie ]
