Full Version: 2 type R 10's sealed-SPL?
H00LiGaN
any idea what spl i could get with 2 of these 10's in a sealed box of about 40litres powered by mrd-M500 making 623rms at 14.4 volts?
[ March 23, 2003, 22:21: Message edited by: H00LiGaN ]
bassmekanik
if it was in my car the volume would be very simalar if not a tenth of a db lower because they handle more power than mine but are less sensitive
Bodyjar
Not much Im afraid... I'd be thinking around 135dB, maximum...
H00LiGaN
aww bugger , any other 10's that i can consider for small sealed with good spl for my power and decent sound quality? or wat about the type r's in there recommended ported box of 28 litres? wat bout type s sub are they much chop?
[ March 24, 2003, 08:41: Message edited by: H00LiGaN ]
H00LiGaN
or would it be better to get just 1 top line 10" with BIG power handling ,i guess that would be louder i reckon
ripped
go ported. sealed is for the weak
H00LiGaN
ok MrSkin wat 10"ers suit small ported boxes and sounds half decent?
bassmekanik
brahma
type r
shiva
elemental
i can get links for all them too
H00LiGaN
ok cook BassMech, only wanna fork out upto 300 max per sub
DD
.. i dont think you can get's 10's to play loud in a sealed box sorry.... maybe in a portd box ... a single 10 in a ported box would be come close to being louder then 2x10's in a seald box
like bodyjar said sealed is for the weak
Bodyjar
I dont think many people have had good success with Type R's in ported boxes, just ask Andu!
In that price range and power, I'd try the Hertz HS250, I will be using ONE of them this weekend at a comp, I'll let you know how it goes Aiming for 143dB...
H00LiGaN
ey BodyJar are they the ones in the online store? any good for small ported, let me know how you go at the spl comp. thanx
Bodyjar
Yeah they're the ones. How big is small to you?
I'll be running it in a 3.2 cubic foot box...
H00LiGaN
LoL basically i can fit 2 30 litre internal volume chambers so im after something that sounds good! and within my volume range sealed or ported with decent spl.
lancerman
Yeah, I have 2 of these subs. Very efficient, and I have got 144.3 with 2 of them in a ported box off my 1507.
H00LiGaN
ok i think i have narrowed it down alittle, either hertz hs250 alpine s type or pg tantrum any others i should look at? and btw ill prolly go the sq route as i cant exspect to much spl with the power i have.
[ March 24, 2003, 19:50: Message edited by: H00LiGaN ]
bassmekanik
trust me 10's can get loud look at my sig hell that is on a good meter too
ripped
alpine type r 10's in small ported boxes have been proven for good spl. bodyjar, the festiva with ther 2 alpine 10's and a crap load of power killed you at kalbar...
he had them in 1.5cf ported boxes each... so thats about 40L per 10...
H00LiGaN
ive checked the specs on the hertz and with a sensativity of 93db they must be good for my application even in a sealed box and with good power handling!! Are they a spl sub or just a good efficient nice sounding alrounder, they seem pretty cheap too, good choice for me perhaps?
The Hertz HS 250s and 300s have an efficiency bandwidth product that is a little on the high side which means it is more suited to ported boxes..
Also, the correct 1w/1m efficiency spec of the HS250 is 88dB..
adavy84
Hey i have some alpine type R 12's in a ported box and they go very nice! havent tested them yet but.
If u wanna see some pics goto http://www.picturetrail.com/adavy84
Bodyjar
Hmmm... yes I did forget about them! Although they did have 2000wrms or so... But yeah, they performed very well..
If its out of the hertz, typeS and PG, I'd go the Tantrum!! especially for SQ purposes, the Hertz will really only like ported boxes...
H00LiGaN
ok thaNKS for that Bodyjar, i assume the tantrums sound good in sealed boxes? Im also still looking so if anybody has any subs to recomend me that sound good with good spl im open to any suggestions.
[ March 25, 2003, 16:52: Message edited by: H00LiGaN ]
DD
im with bodyjar
the PG's are the best choise i have had my PG in a selaed box .. soudn's good to me ... evem know im only a SPL guy .... and the PG can handle the spl as well 146.9 is my best so far ...
H00LiGaN
Ok thanks for that DB_King my decision is getting easier..
H00LiGaN
how small can i go with tantrums in a ported? i read there manual and they suggest for musical go 1.2cft ported @35hz or spl 0.95cft tuned @48hz, so i figure chop 3 litres off the 1.2cft box and tune it a fraction higher, would that be a good compromise between SQ & SPL ?
H00LiGaN
UPDATE, ok i have reasessed my plans, i can move the box forward of the diff hump which will give me alot more height for the box. That being the case i should flick the 10's and move to 12/'s, from what i have seen, ill need a wedge shape box and prolly max internal volume of 2cft, so therefore should i go 2 12's sealed or 1 twelve ported, i still want good clean tight LOUD bass, so what ya think?
Bodyjar
One twelve ported
ripped
shocker audio ss 12"
DD
single 12 ported .. really low .....
H00LiGaN
shocker SS wats there price and box size for it?
ripped
http://www.caraudioaustralia.com/ubb/ultim...ic;f=2;t=004105
i have 12's and 15's coming, so i'll let you know on results. box size would be 2-3cf ported.
H00LiGaN
yeh i just noticed they are dual 2ohm, no good for me :/ Doh!
ripped
hehe. get another amp
H00LiGaN
ill like to ad i need a 2ohm load.....so 4+4 or a single 2ohm sub like the cadence.
