Full Version: JL spl Setup with ballz
bassmekanik
i now have my amp and all ready to go now i want SPhell i got 350 rms per sub and hell loads of boot space aprox
435 high
980 wide and
500 deep a ported or sealed box i don't care i want spl no sq is required please help me..
ps will these beasts take all that power
Bodyjar
Are we talking JLW0's here?
CHIEF
For burps, the JL's should handle double that.
bassmekanik
yes wo's single 4 ohm 15 inch
bassmekanik
does NE1 have more opinions suggestions or any thing they will be getting 350 rms each ported to my res freq and 93.2 litres per sub
Bodyjar
Sounds all good to me!
bassmekanik
can you estimate an aproximation of what sort of SPL i might be in the region of
What do you mean by "ported to my res freq"?
First of all, you want your box/sub to peak at the frequency that gives you the most gain, from both the cars cabin and the sub/box combination..
So therefore the peak frequency that you use can vary not only due to the car, but the equipment used and the box location etc..
Secondly, the box will peak above the tuning frequency.. Tuning the port to the frequency you will be playing will result in a lower SPL reading.. The best tuning frequency is usually between 5-20hz below the frequency that you will be playing.. It depends on the sub, box volume, sub and port location, amount of power and SPL etc..
So basically there are a lot of factors to be taken into account and it is often easier to do the testing than trying to accurately predict what will work..
As a starting point, with around that amount of volume and in that car, I'd tune to around 37hz with 25 square inches of port per sub - ie 2 4" ports per sub or equivalent slot or square port..
bassmekanik
i was thinking 2.9 feet each tuned to peak at my res freq with a single 5 inch port but i will do a 4" one if nessasary i am thinking of making external ports for looks and also to help increase box size on win isd i got dugger all port velocity with the 5" all i want to do is BOOM and be able to adjust the port for a little bit of music listining on the way Home from comps
Bodyjar
You'll need bigger ports than 4"!
Yeah.. I recommended two 4" ports per sub, ie four 4" ports total..
bassmekanik
righto here is the FULL specs 2 completly separate boxes 2.9 feet per box tuned to PEAK at my res freq.
ports facing up and subs facing up ports will be 50% in the box and 50% out of the box to keep the height down and volume up a bit..
ports will have an extender for daily driving if nessasary..
what sort fo spl might i be able to expect from this with 350 rms per sub..
sneaking near 150 ya reckon
Earthquake
NO CHANCE Buddy, or less you cabin is the size of a Fridge
man have a look at termpro and check out what ppl are doing across the world!
bassmekanik
will i be better off going with one type r 15" instead of two JL WO's i was just hoping
oh well i will just get what i get
Vega
I'd be thinking more along the lines of wots in your sig with that amount of power
Mr_Bob
i think you could get close to 150, (not on the new termpro meter though)
but you'd have to have a wall, and alot of time, tuning and patience.
bassmekanik
Why is that???
i cannot realy have A wall setup that would be too much stuffing around.
i am hoping to be pretty high i will be looking into which car to use soon either 1988 mazda 323 hatch or 1986 pulsar hatch (not ET )
does anyone know which would be a better car all round
Earthquake
Dude you only have 700wrms, you need more power more cone area, more box and more port
Man what class do you want to pull 150dB in??
Like Mr. Bob said you can hit it quite easy in a wall in super street, but if you want to hit it on street it will be heaps more of a challange
Look at what power Car Acc Installs have!!!
2 MTX 1000D's and a MTX RFL 15" in a huge box, with heaps of charging upgrades, 0-awh wiring ect/
Have a look at UDL's car this Sunday, he has only 700wrms and a 15" and see what he does with it
bassmekanik
next sunday ya mean it is not the 6th yet i don't care about the class i want to do the best i can 150 is just what i want to do by january next year and i will too look at my post in tassie spl competions and read my last post on page 4
