Full Version: 4 + Rotors (NZ)
Clarkie
Used the new termpro suck on mic's today at rotor show,boy are these puppys mean 6 to 6.5db down on the old termpro ones.Thats from EX down to st classes all seam to be 6+db dowm.
Some of the scores
SS 3-4 wall 4x15 No11 + 4 bp1200 151.7db
SS 5-8 6x12"cheap DVC + 3xNo11 amps 147.?db
SS 1-2nw 1x12"3512 + 1XKenwood x810d(me) 145.1
st 3-4 4X12"hx2 + 2xbd1500 147.3db
st 1-2 2x12"as in sig below(me again) 144.1db(NZ record 144.4db)
Mics are great did 145.1db twice with suzuki in different lanes and 144.0,144.1 in the laser.I get more results later very tied,later boys
Clarkie
Andu
you guys felt the meter change hard! At Auto Expo we had a 146.9db in CAAdB StockA class which is the same as the old st1-2 class.
ripped
going on those results, it looks like the australian old termpro (used at FB) was a lot tougher then the other 'old termpros' around the world...
Bodyjar
Indeed.... So I guess its a race to do the first 150 in street eh?
I'm sure most of us had been suspecting that for quite some time..
bassmekanik
holy crap them meters must be harsh if the race for 150 exists
ripped
i dont think it'll happen this year... it's be hard. i think andu and the doran car are closest at about 147db... 3 db is a big jump, esp when you have to have the engine off. no point wanting 150 in street if there are no db drags. people have said QLD will get db drags, and CAAdb comps... but still nothing. i think QLD members should support the guys that are hosting the comps locally, eg autobahn, mcs and the like and run our systems in their classes.
Bodyjar
You have a point John...
Andu
Well in Australian db-drag history there has only ever been 1 car to crack 150 on the db-drag termpro, and only managed to once with a 150.3
And the only new meter in the country is run with CAAdB rules so we have a disadvantage of only being able to run 1 amp against everyone else in the world. So I definitely don't see 150 on the new meter being broken in Stock A anytime soon.
Current Street A world record is held by Eric Coulter with 151.0db backed up with a 150.9db
Bodyjar
But in Stock A, you get to have your engine on...
Andu
[b]
But in Stock A, you get to have your engine on...[/b]
engine on/1 amp or engine off/2 amps
for maximum spl... I know which option I would be choosing
Clarkie
Rippedskin what makes you think the Oz meters(old termpro)reads high,according to Wayne Harris the old mics only ever read high when out of calibration not low.
Eric Coulter car is a monster to pull 151db on the new mics is orsome that was at spring break correct?The NZ record in st 1-2 is 144.7db by Bart up north with 2 12" JBL Gti subs + 2 R/F bd1500 amps so I pretty happy to be not far behind with a 1000watt amp and light duty kenwood subs.
Clarkie
Clarkie
Doh Doh
D Post
[ March 30, 2003, 18:12: Message edited by: Clarkie ]
Bodyjar
He thinks it used to read lower, because Hardon did consitent 151's on the old meter, but when on the new meter, he only did a 148. Thats only a 3dB loss... whereas the USA and NZ has found 6dB losses...
I have an idea why Angelos old termlab setup could read low, but I'm not going to say..
But I started suspecting it when all other termlab and freshly calibrated audiocontrol mics all over the country seemed to read almost exactly 3dB higher than Angelos setup.. Also the new termlab setup only seems to read around 3dB less than Angelos old setup.. Coincidence?
Clarkie
So I take it Angelo has the new Termpro mic set up?I wasent sure if he had one,someone said they were going to use the old termpro this year and buy the new set up next year??
Clarkie
Andu
Clarkie
Angelo has the old setup and as you said will be using it all this year. CAAdB are the only ones with the new Termlab in OZ
