GSR10T
Mar 20 2003, 02:55 AM
I'm new to the world of SPL, and am currently building my first system with the hopes of some descent numbers (mid 140's). I'm still purchasing the equipment, but my set up will consist of:
2 x Alpine 15" Type R 4+4ohm DVC subs
1 x Coustic 600SE amplifier
I am setting it up so that each sub presents a 2ohm load to each channel of the amp, giving me 300wrms into each sub. I also have a crappy Boss Audio amp running my front stage.
My question is, what are the limits of the stock battery and alternator? Is there a general rule of thumb for when you need to upgrade? Also, how much would i be looking at paying for a new battery and alternator?
[ March 19, 2003, 12:58: Message edited by: GSR10T ]
Loudrolla
Mar 19 2003, 05:32 PM
I dont think you would need to upgrade with that much power. Really you are only running one amp in a comp so maybe just upgrade your stock battery to something a little beefier & make sure you run at least 4 gauge down the amps.
BlackIce
Mar 19 2003, 07:07 PM
Knowing what car we're talking about would help..
But anyway. Fit the biggest battery you can afford (and fit in the car), upgrade the power cables, earths & alternator cables to atleast 4gauge and see how you go.
hardon
Mar 19 2003, 07:56 PM
Or install the gear, if the lights dim during bass thumps then it indicates the power supply (ie. the alt and battery) needs to be looked at.
Yeah, I'd start with 4AWG cable, 4AWG from the engine block to the chassis to the battery (probably during the install of the gear) and take it from there. A battery would probably be next (in my opinion) and then the alternator.
Good luck, we SPL guys need as many bodies as we can!!!!
(coz SQ is for grown-ups!!!!)
Mar 19 2003, 08:12 PM
You do realise that you have bougth subs that take over 1000wrms for an SPL burp and you will only give them 300wrms??
Thats a huge mis match, u should go with the two 12inch Type R's which are cheaper and then spend the money saved on a bigger 1 kilowatt plus amp.
Will go heaps better
bassmekanik
Mar 20 2003, 01:29 AM
oooh that is a bugger about the amp
bet a batery as big as you can fit into the stock location without modifing any thing get bigger earth and alt to battery cables then if the lights dim get a bigger alt that is my idea i just gotta save for the 640 cca truck battery to fit my car in stock location
the truck battery will fit in my case measure urs up to see
GSR10T
Mar 20 2003, 03:16 AM
I realise my current amp is underpowered for the subs. But i dont see a point buying 2 smaller subs when i'm just gonna need to buy bigger subs AND a better amp in the future. I don't hage huge amounts of cash to be shelling out, so this way i can keep these subs for a long time to come, and if (when) the time comes that i crave more, i can simply buy another amp and problem solved.
Also, the car is a 1990 Lancer GSR hatch. Thanx for your help guys, i'm building the enclosure now, so when its in i'll give you an update
Andu
Mar 21 2003, 02:33 AM
Well if you don't have large amounts of cash I wouldn't be upgrading your electrical system, sure a better electrical system is a good basis for an excellent system. But if I take for example the Doran Suzuki Swift that took out first place at Auto Expo... L7's with a VR2000 (probably around 200A current draw) hanging off an average 470CCA NRMA battery. The best upgrade you could make would be a bigger amplifier.... and concentrate on tuning the box.
Mar 20 2003, 05:07 PM
if you go with such a small amp theres no need to upgrade the battery at all teh standard 470CCA battery will be more than up to the task. Im drawing 3 times as much power and i've still got the stock electrical system
GSR10T
Mar 20 2003, 05:57 PM
Thanx for all the help guys. I'm now putting the money intended to upgrade the electricals towards a new amplifier setup. Speaking of which, what would you suggest i use to run these subs? Keep in mind they have dual 4 ohm coils
bassmekanik
Mar 20 2003, 08:22 PM
look in my sig 380 cca battery an stock 60A alternator np probs just upgrade the -ive wire and ya shuld be good
hardon
Mar 20 2003, 09:36 PM
I was just gonna state that if you are under powering your subs by a big difference in subs rating vs. amp rating, but very careful...
If the amp is making max power and the subs aren't doing much, you're inclined to wind volumes and gains up - then the amplifier could clip and the subs could be damaged in a short time....
Just a warning to watch out for....
cya
vanboy
Mar 22 2003, 07:53 PM
nuffin wrong wif the afforementioned vr2000d
hardon
Mar 26 2003, 09:17 AM
A nice D class Monoblock would be the go!!!
I'd recommend Earthquake, but everyone on CAA has had problems with the D2 model....
ripped
Mar 26 2003, 12:18 PM
only richie
nemesis
Mar 26 2003, 12:55 PM
ive never had any problems....except for blowing up subs
hardon
Mar 26 2003, 10:40 PM
I've never had a problem either, but most of us have read that followed that thread where one D2 blew after another....
vanboy
Mar 31 2003, 04:41 PM
;P
kmart amps
