i_am_maximo
Mar 27 2003, 07:17 PM
JBL P1020
10" SVC
400w-1600w power handling
$399
JBL P1220
12" SVC
$599
Schneider SPL-12DV
12" DVC
500w max
What are your thoughts on these subs.
I am leaning towards the P1020 but if there is anyone out there who can nudge me towards the others, I might reconsider them..
Also anyone know the price of the Schneider SPL-12DV..
Bodyjar
Mar 27 2003, 07:28 PM
Why you restricting your choices to those subs for?
BlackIce
Mar 28 2003, 10:51 AM
All I could extract from Schneider's website:
< SPL-12DV >
30cm (12") Subwoofer
Features:
500 Watts Power Handling.
50mm Dual Voice Coil with Dual 50oz Magnet.
Polypropylene Cone with Large Rubber Butyl Surround.
Aluminium Cast Basket.
Recommended Sealed Enclosure: 34 litres.
Knowing Schneider products its sure to be pretty well priced (~$200 I'm guessing). I've seen them, never used one or heard them tho. Being DVC will make it more versatile than the SVC's.. But I've also seen good numbers coming from JBL SVC subs.
But there's better SPL subs out there than all 3... unless your budget has limited you then either of the 12"s should serve you well
i_am_maximo
Mar 28 2003, 06:48 PM
< SPL-12DV >
Features:
That's how I found out about the schneider subs, went to the site to check out a couple of their amps and decided to have a look around..I also like the PRO-DV12 the have.
I am not really restricted by budget, but I am looking for a good thumpy sub without the price tag capable of giving me a heart attack..
If I had a budget, it would probably be around $500 per sub(I want 2, but I don't want 15s)
$1000 for the sub amp/s(looking at Schneider SPA4000HC(2x540@2ohm)..
List your choices not limited to these three subs..I need more info..
i_am_maximo
Mar 28 2003, 06:50 PM
I'm not restricted to these three subs, I just wanted to find out what people think about these subs..
BlackIce
Mar 28 2003, 06:59 PM
Quantum 4 channel.. nice little amp. Just so happen to be using one as my interim amp just to get some DOOF into the car. 141dB on the new CAAdB termpro with a pair of 12"s driven off it .
Don't go forking out $1000 for one tho.. you can get them a fair whack cheaper than that. RRP is $900, and with some bargaining you'll get a decent discount off the price.
Slightly related: The local audio shop owner told me a story about a young fella who bought one of those Schneider subs. Stuck it in a pre-fab enclosure, inverted it to show off the frame and went cruisin' that night. It was wet, it was muddy, the sub wasnt bolted down and he had a plastic jerry can of fuel in the back. Lost control, sub slammed into the jerry can, petrol into voice coil vent, flames. It would seem they are NOT fuel or fire proof.
i_am_maximo
Mar 28 2003, 09:21 PM
[/QB]
My local dealer has one SPA4000C left, they are about to stop selling Schneider, that's why I asked in another post if anyone knew any Schneider distro's. Back to the subject, he has one left at $740 but he has a few other interested parties and I don't have a derposit for him. But ~$900 ain't to bad for 2x540w@2ohm.
i_am_maximo
Mar 28 2003, 09:22 PM
[ March 28, 2003, 19:27: Message edited by: unsecret_agent ]
Bodyjar
Mar 29 2003, 12:45 PM
If you have $500 per sub, then I'd recomend the Kicker L5's/L7's... You should be able to pick up the L5's for about $400 from JBHifi. And they will kill any other sub in that price range...
If you're looking for amps around $1000, the Crossfire 1000D comes to mind, with 1000wrms@1ohm, but puts out a little more... Or the Cadence A7hc is it? about $1100 I think...
i_am_maximo
Mar 31 2003, 05:56 PM
I am not really into kicker richie but I'll go and check them out, and Black Ice check pms pal..
Bodyjar
Mar 31 2003, 07:21 PM
Well if you want to win, you have to be open to everything, there is no room for brand racism in SPL!!!
lancerman
Mar 31 2003, 07:36 PM
Max, put that Sony 12" in a big ported box and hook it up to a big amp like a 1507. You might be surprised what sort of results you will get...
BlackIce
Apr 1 2003, 10:28 AM
unsecret_agent: I have checked my PM's and there's nothing from you
Resend it
i_am_maximo
Apr 1 2003, 03:02 PM
Lancerman: That's the plan, 3 cuft box with 2 4" wide variable length ports. As for the amp, I was thinking a Jaycar 2x150(438 bridged), Just until I can find and afford a Schneider SPA4000HC(2x540@2ohms) and then I will get a type R 10" or 2.
BlackIce: Will do.
Bodyjar:Which subs are they, the EX, comps etc.
And I'm not brand racist. Just haven't heard much good about kicker.
[ April 01, 2003, 13:20: Message edited by: unsecret_agent ]
lancerman
Apr 1 2003, 03:34 PM
Bodyjar was refering to the Kicker L5's and L7's. They are the square ones. They're not cheap but have a great reputation for big SPL because of their greater cone surface area compared to round subs...
i_am_maximo
Apr 1 2003, 03:44 PM
Lancerman: Oh cool, I like those subs, and I can get em really cheap from JB macgregor, how much are the 1507s??
lancerman
Apr 1 2003, 03:52 PM
They don't make 1507's anymore, but if you find one second hand it should be around $650-700, depending on condition. I think the could be bought about $900 new. Its rated at 1x900wrms @4ohms at 14.4v.
You'd be hard pressed to find another class A/B amp that puts out that much power at 4ohm, especially at the price.
I might not make it to MCS this weekend, but if you see Dave (323alpine) ask him if you can stick his 1507 for a run in your car.
i_am_maximo
Apr 1 2003, 04:03 PM
My car is in the workshop again, but it's the engine & brakes this time, that's why I asked, might see if I can get a lift with someone else.
[ April 01, 2003, 14:06: Message edited by: unsecret_agent ]
