Full Version: Box size for IDMAX12v3
stoff
hi guys,
getting my new sub soon as in the topic.
so now need to start building a box..
what size should i be building?
i listen to r&b/rap mostly, and jazz occasionally.
thanks
chris
adrianf
1.5 net should be about right for what you listen to
depends on the specs: Fs, Qts, Vas in particular.
if you can get the 'v3' specs then good. otherwise, these are off the website, but i don't know what 'version' they're from:
Fs 27.7Hz
Qts 0.389
Vas 99L
based on these, i'd go:
*2.5cuft nett, tuned to 28Hz using round 4x14" port
*sealed 1.2~1.5cuft
there's never any 'perfect' box. ported is probably the way to go though, for added low-end response. note that these suggestions correspond with ID's own:
http://www.imagedynamicsusa.com/website/te...et_idmaxd4.html
also, the DVC 2+2ohm specs are slightly different, but don't alter things much.
and, the v3 specs may be different again.
mjjensen
Hey,
I'll be building a 1.3 cu.ft gross box for mine - maybe a little bigger. I found that at 1.2-1.3, the woofer has the lowest group delay - minimal, but may still improve transient response. I "think" the woofer is 0.12cu.ft, so ID recommends 1.18cu.ft net.
I'll probably aim for 1.2-1.3 net, but i'll check it out in WinISD today or tommorrow.
Michael.
VL Commy
michael, when u gonna come to a meet so i can check out this IDMAX in the flesh??
mjjensen
Soon!!
Cabling and sound deadening this week, sub box next week and amps the week after (if they arrive).
I've got shieldsy's number, so i'll get around to it soon - i promise. smile.gif
michael.
stoff
thanks.
would you guys suggest going ported over sealed if i have the space?
its most prolly now gonna be running off a Ti800.1 so around 900Wrms.
stoff
hey shiny,
you mentioned this for the ported box. "2.5cuft nett, tuned to 28Hz using round 4x14" port".
now i've never built a ported box..how would i go about doing this?
do i just build it as if it were a sealed box of size 2.5cuft nett, except it has a round port? is the diameter 4", and the length 14" of the port?
where should the port be placed?
also, how do i tune it to 28Hz, or is the size + port already tuning it to 28Hz.
thanks
chris
for ported, the quoted box sizes are usually 'net'. this means you need to ADD on the 'volume'/displacement of the port. a 4x14" will displace/take up about 0.3cuft (pi x r^2 = 2.14x4x4 cu.in / 1728 = cuft). so add that onto 2.5 and you need to build a box around 2.8cuft.
'tuning' it kinda sets the roll-off frequency. using that port and box combo will 'tune' it to 28Hz.
ID themselves give lots of suggestions. as such, i'd wait until you get the sub with its manual, which should include all the latest specs and box designs to suit.
adrianf
there is a ID forum on sound domain forums. the box size question has been ask and answered many times by ID people. so might be a good start to have a peak in there aswell smile.gif
