piezo's is kind of a bad term! there actually a composite(paper) cone that is powered by a piezo plate.
they have a small light globe inside them that acts as an impedience regulator of sorts, when you give them heaps of power, and i mean heaps(some piezo's can handle 400wrms per driver!) of power the globe begins to glow increasing its impedience' which in turn reduces there output to a degree, it makes them virtually indestructable! they can play flat out forever!.
unfortunatly they dont have them on coil design ones so there is a limit to them, but replacement domes are usually redilaly availible reasonably cheap' some even come with replacements and its a matter af screwing the new ones in, simple!
a comparison is a little hard' there vastly different types of speakers and completely different sounding' there has always been arguements over horns v's conventional tweeters, in the end they both have there pro's and con's
i would definately say for absolute naturalness in sound' conventional tweeters would be on top, but horns will offer a better image etc and will always beat them with dynamics at huge volume levels, where they sound like a tweeter the size of a 15" sub!!
they will always require equalization to sound excellent were as a component set can sound excellent without it 'just carefull placement!
one other downfall is that they can make you go deaf very easly :| and i mean that seriously! there definatly not something to listen to at loud volumes in close range
