QUOTE (Winno)
Personnally I have often admired characteristics like transparency, imaging and the sheer ability to convey the emotion of the music that some valve amps are capable of.
Measure that on your scope
I couldn't care less about the specs if it sounds good. The only test equipment I often use is the one between my ears.
If you don't understand what I mean, you've missed the whole point.
Well I always say:
"If you can hear it, then you can measure it, but just because you can measure it, doesn't mean you can hear it".
This means that speakers/amplifiers can be engineered to sound good.
Obviously, if you can really hear it, but can't measure it, then you are using the wrong tool to measure it. Of course to most people understanding how it really works is irrelevant, as long as it sounds good. But to those who care to know, or need to know, then it is important. Naturally, since the end result is you will be listening to the amplifier, it is important that the design is not only theoretically correct, but is actually correlated with how it sounds. But remember, that sound is not only heard by your ears - the thing between your hears has a role too and can be easily influenced...
QUOTE (HISPL)
HOWEVER- When a tube amp starts to clip the waveform "baloons"
and is still relativly smooth rather than having a "squared off" edge on the waveform like a transistor amp.When a Tube amp clips it has audiable distortion opn even harmonics which is easier on the human ear than odd harmonics which is what is produced when a transistor amp clips.
If there are increased second order harmonics, then the wave will become more sawtoothed, rather than squared off. A rounded off edge will occur if there is limited bandwidth - if you lowpass a square wave, then it will look more rounded.
QUOTE (HISPL)
Tube amps do not color the sound to any discernable extent as compared to transistor amps. If both amps are producing a smooth waveform you couldn't tell the difference this goes for any amp.
Yes, correctly (well) designed amplifiers do not audibly colour the sound...
QUOTE (HISPL)
The output impedance of a tube amp is virtually infinite.
Ideally the output impedance of the amplifier should be close to zero. In the real world, as long as the damping factor is high enough, it will be fine. Most tube amplifiers have damping factors that are low. As you know, the impedance of a speaker is not completely flat - if the damping factor is too low, then those frequencies where the impedance rises will be accentuated.
QUOTE (TRU Tech)
Let's have a challange:
Use 3rd party Audiphiles (non-car audio)
Ok, it is obvious that your point is that certain "Stereophiles" (ie the ones you'd pick for the test) prefer the sound of these tube amplifiers. My point is, that if you gave the transistor amplifier an equally low damping factor, then the stereophiles may find it hard to tell the difference. Otherwise, I could just as easily find a bunch of people that dislike the sound of a low damping factor - but this wouldn't prove anything.
Nevertheless, if colouration of the sound is desired, then these days you can do whatever your heart desires with dsp. With a very flexible EQ, with the ability to simulate the response of various classic lo-fi amplifiers, as well as ability to add as much 2nd order distortion as you desire etc. (for car audio, TA as well, and for the nostalgic, a white noise generator. :wink: )
However, for some reason such a product does not exist yet. Whereas, in the musical instrument world, manufacturers already make products that are able to accurately simulate the nonlinearites of classic speaker cabs/amps.
