QUOTE (subwayboy)
So with the morel setup Morel HCW8 8" and supremo's would there be frequency gaps, or would they sound alright?
Also how would you run this combination, active, or with a custom crossover?
There would be no frequency gap, it would extremely good. The Supremo's play really low down to 2000hz with ease.
Custom passive or active is hard to choose, if you have a headunit such as an alpine 9815 that has active crossovers on it and a spare amp then i would definitely go active.
However if you only have a 2 channel amp and a headunit without crossovers then i would go custom passive as it will work out cheaper.
Do you have an EQ because passive crossovers are very hard to get right the first time. They require much testing.
If your going active i would just get horns. Some image Dynamics CD1e Minihorns are just on $600 which is just cheaper than a pair of supremos. The Minihorns would have better imaging and volume than the supremo's by far, but the supremo's would have a slight edge in crispness. With time alignment it would be hard to get them to sound excellent on both sides of the car, where as with the horns they will image excellent in either the passenger seat or drivers.
Instalation for both would require a bit of custom work, a 3inch tweeter will require custom kick panels, and the Mini horns will have to be attached to the underside of the dash and may require some custom work also.
Because your going with 8inchers, it suggests that you have pretty loud subs, and if thats the case then the horns will win hands down.
