i am considering a APmat setup in my next system, there's not many car audio brands that make them' im using some made by image dynamics but they don't sell them any more!. USD make them and sell them for most of there woofer range' there site explains a little
www.usdaudio.com
really you need an impedience meter to tune them properly, a RTA has not enough freq in the sub bass range to do it effectivly, you could make your own its just a fiberglass matt type stuff that allows sound to travel through it at a desired rate or can be ajusted buy altering the density of the material witch in turn changes the impedience curve.
with an impedience meter you 'tune' it to have the flattest curve possible.
due to there lowish efficiency?power handling it is recomended to use 15" or larger speaker to get output with little effort also because the mat simulates a optimum sealed box .
i have also been told that you should have a APmat area thats 1.5 times the area of the driver, but im not shure thats true though
