Full Version: Some Advice Newby
Streatz
Hi people
Im redoing my install and wondering what you all think of the following products regarding sound and performance
4x Kicker S10L7 (New silver ones)
1x Kicker KX1000.1 (To Run Subs)
1x Kicker ZR240 (To Run Front Stage 6 inch Splits)
1x Kicker 6.2 Front Stage 6 inch Splits (Mid Bass)
A Pair of Horns (HLCD) not too sure what brand yet (for Front Stage)
1x Kicker ZR240 to run Horns
1x Rockford Fosgate EPX2 Crossover
1x Kenwood DVDscreen Not too sure which model yet but possibly last years model
Let me know what you think all advise good and bad appreciated
PS ITS GONNA BE SET UP FOR SQ N SPL
done
How are you going to power those 4 subs with that amp?
pingpong
don't see why not, it might not be an optimal amount of power for each sub, but I can't see why wouldnt it work?
ultim8DTM5
QUOTE (done)
Probably either in series or parallel
Streatz
QUOTE (ultim8DTM5)
QUOTE (done)
YES they will be in series
and thanks peoples for your advise keep em coming
>WAYCON<
What brand are you looking at for the horns? I only ask because comparitively (pricewise), you are better off running a standard or higher end tweeter, eg. esotar, supremo etc. But if they are higher end horns, then that would sound reat. But that would leave the question as to why you would only run 6.5" mid-basses? If you are buying high qulity horns, they should be hitting the 500-900 hertz region. And considering the amount it looks like you are going to be spending, running a 3 way front (5-6" & 7-8") would leave you much better placed.
And as was mentioned above, that 1 amp for 4 subs doesn't sound like it will be all that competitive in the SPL front. 1 over powered 15" would go much harder than 4 underpowered 10's or 12's.
And while on that subject, why are you going the kicker amp? Obviously money not appearing a problem, why not buy multiple calibers and strap for maximum impact. That would go alright!
Keep us posted
