Lithius
Aug 11 2004, 05:35 PM
Hi just got my system planned to install into a 1989 Nissan Skyline GTS-4. Is there any obvious part that should be upgraded, which might otherwise mess up the whole experience?
Clarion ProAudio DXZ835MP MP3/CD/WMA
PHOENIX GOLD Ti500.4 Titanium
BOSTON ACOUSTICS ProSeries 5.5 System 5.25" COMPONENTS
MTX Thunder 1501D 1500 WATT MONOBLOCK
JL Audio 12W7 12" Subwoofer
Jimbo
Aug 11 2004, 05:58 PM
im assuming you're bridging the PG amp..
the things i would consider changing, would really be only the front stage.. as the Pro 6.5 would put out alot more midbass..
other than that the MTX could be upgraded if used a SQ application... and it doesn;t have to be 1500wrms
gooki
Aug 11 2004, 07:06 PM
Overall it loosk like you're on the right track.
UsedBC
Aug 11 2004, 08:01 PM
w7 is a 13" not a 12" and i'd go a better amp, something like audison personlaly
meh
Aug 11 2004, 08:08 PM
QUOTE (Usedbodychocolate)
errrrrr..
http://www.jlaudio.com/subwoofers/12w7.html
QUOTE (Custom Car Sounds Website)
12W7-3 (3 ohm) 12" WOOFER, 750 W/RMS, 1800 W/PEAK $1,498.00 EA
As the 12w7 is single 3ohm, id opt for something like a JL 1000/1, which will give you power from 1ohm to 4ohm.
Your system sounds good, however id definately try and fit some 6.5" mids if possible. Look at the PG Elites, Morel Elates aswell as Dyns, Focal, Hertz and ofcourse Boston.
Stooge007
Aug 11 2004, 08:26 PM
i'd say it depends on what your budget is :wink:
if you're talking SQ, i'd be looking at:
AMPS - Audison, ARC, Zapco, Tru
SUBS - Image Dynamics, DD, Boston, Diamond
SPLITS - Boston, Dyn, Focal, DD 6.5's + some tweets
- Stooge007 out
ultim8DTM5
Aug 11 2004, 09:54 PM
QUOTE (meh)
errrrrr..
Dammit you beat me to it.
UBC: why is the MTX a bad amp? why is the audison better?
jas
Aug 11 2004, 10:22 PM
why in the world would you want to change your system???
are you unhappy with it??
if not look at a different install
the 12w7 3ohm sub will receive at least 750watts rms @ 12.5volts and 1000watts @ 14.4volts
that should be enough
the boston tweeters are a little harsh for my liking but installed the right way will sound awesome.
its all about install the componets chosen are all top notch
dasherhalo
Aug 12 2004, 09:06 AM
Hey Lithius, are you unhappy with the system? That component list is rock-solid on paper, so are you unhappy with a particular aspect?
ultim8DTM5
Aug 12 2004, 09:51 AM
Components are easier to change than installation for the lazy
Lithius
Aug 12 2004, 04:52 PM
No I don't have the system yet, I took out a loan for a car with a few grand extra to spend on the sound system. So i've got the car, and the extra money is sitting here, just wondering if what i've got in mind is any good...
I'll get the 6.5" Components instead 'cause they're the same price anyway.
Are MTX amps bad in the SQ department? Would a PG Xenon 600w Monoblock be better?
