QUOTE (DaN tHe MaN)
just had a look on the JL Audio website for the enclosure specs of a JL12WO8 woofer, and was somewhat confused with the reccomended volume
instead of having an exact figure like most manufacturers do, they gave a range of quote, ''Sealed Enclosure Range: 1.00-1.75 cu.ft. (28.3-49.5 liters)"
the important thing to realise is that there is never a 'perfect' size box for any speaker or sub. instead, there is always an 'acceptable range'.
also note that 'sealed' box designs are quite forgiving, so a largish range is applicable, where you won't hear huge differences between the smallest and largest recommendation.
aside from this, there are far more influencial matters that affect subbass performence, including the position of the subbox in your boot.
as such, applications and needs vary from one situation to another, so there cannot be any 'best' setup.
having said that, as already noted, smaller takes up less space, can improve power handling, but at the expense of low-end response. larger can improve low-end response, but may be a little less accurate. if you can hear the difference, you're doing well though.
