vespa
Sep 2 2004, 03:25 PM
hey guys, just got my greasy little mits on a new boston pro 10.5 inch but now it has come time to build a little box. I have decided that i want a sealed box as i think (correct me if im wrong) it gives out better sq. I was planning on following the reccomendadtions in the manual for a box size but according to boston i should have a 14L box, now that sounds a bit too small?
recco dimensions are:
H:7.5"
W:11"
D:11"
toating at a .5 cubic ft.
it also reccomends to use 1" thick mdf which i am finding abit hard to find. ne of you guys got a idea where it can be found?
any input would be appreciated.
Sep 2 2004, 03:38 PM
i got my pro 10.5 in a 1.8cft box, sounds damn nice.
icacha
Sep 2 2004, 09:32 PM
1" is 25mm MDF, most hardware stores should have it, but you can also use 18mm MDF with no problems.
Winno
Sep 3 2004, 10:17 AM
Boston recommend 0.5cu ft (or 14 litres) as the internal volume. External dimensions will then obviously be greater.
Even though this seems small, it works extremely well.
Sep 3 2004, 02:34 PM
QUOTE (Bobby_Digital)
ah yes, i think i recall suggesting such a big box might suit. and indeed it sounds great, playing very looooow.
so i think you can afford to use a bigger box if you can fit it in the boot.
Sep 3 2004, 03:23 PM
QUOTE (shiny_car)
it also was good cause i only have 220 odd wrms on tap.
if i put it in a .5cf box i doubt it would move!
i did have it in a 1cf box and diddent like it as much
vespa
Sep 5 2004, 07:39 PM
well this 10.5 should be getting upto 900wrms.... so would your reccomendations change....???
-DJ-
Sep 6 2004, 12:44 AM
what car is it?
Sep 6 2004, 09:53 AM
QUOTE (vespa)
if you have the room i would go the larger box.
if it is not going to be a showy install, just build 2 box's, one large one small and have a play.
vespa
Sep 6 2004, 01:36 PM
its going into a lancer so i have a bit of room. as far as buliding two box's i am not too good with wood so i will just be paying somone to do it..... and the price will be too high.
