Introducing the CRO
Here's my CRO. Its an Army Surplus BWD509B single trace CRO thats not too flash and over 20 years old. But it does the job, handles more power than I can ever feed it, is reliable and cost me a carton of VB tinnies.
CRO's looks pretty daunting, so what does everything do ?
Intensity Knob (Top Right) - This turns on the CRO and adjusts the brightness of the trace on the screen. Adjust it however you like.
Red Dot above Intensity - Indicates if the CRO's turned on. This is handy as the CRO can take a few seconds to warm up and start showing a trace.
Three Knobs Under Intensity - These are used to adjust the traces horizontal position on the screen, adjust focus, on screen start & end points & on screen trace width. Adjust these so the trace is clear, and the trace starts on the left of the screen and goes across to the right all the way.
Volts/CM Knob (Bottom Left) - This adjusts the sensitivity of the CRO in Volts, and adjusts the size of the waves on the screen.
AC/DC Switch (Under Volts/CM Knob) - This switches between AC & DC volts. You want to measure sine waves, so put this to AC.
Vertical Position Knob (Center Bottom) - This adjusts the vertical position of the trace on the screen. Adjust it so the trace is roughly centered.
Time/CM Knob (Bottom Right) - Adjusts the bandwitdth of the display. A bandwidth out of range will results in a CRO trace that doesn't pulse and/or display a signal.
Trigger Level (Under Vertical Position) - This is used to adjust the trigger level if you are testing a conductor carrying multiple signals. For our purposes, Automatic Trigger is the best setting.
Three Sockets Bottom Right - These are used for calibration & advanced CRO techniques we dont need, so you can safely ignore them.
Not pictures is the CRO probe. A CRO probe looks a bit like a pen, when you pull the top down a little hook pops out, thats the CRO probe tip. Connect this to the outer ring of the RCA, the little aligator clip is for the reference, so connect it to the center pin of the RCA. As we are measuring a sine wave, the CRO is in AC mode and polarity isn't an issue. This is the same when CRO'ing an amp.
Here's three examples of incorrect CROing techniques:
This is what happens when you try to CRO with music instead of a test tone. Notice how the wave is not uniform and very jagged ? This makes it difficult to know what your measuring. The line through the middle indicates silent sections (image take with a slow shutter)
This is a nice sine wave, however the Volts/CM sensitivity is set too high and can make it difficult to define the tops of the waves. The line indicates silence (slow shutter speed, silence is due to track change)
Another nice sine wave, however this time sensitivity is set too low and the peaks/crests of the waves are being chopped off by the screen.
