I came across a thesis that deals with HRTFs, IID and ITD. Fascinating subject! Just from skimming the thesis, I came to several conclusions:
1. The human body (from the top of the head to the tip of the toe) acts like a sound filter.
2. The binaural cues (ITD and IID) are important parameters to pinpoint sounds from the azimuthal plane (left right). But those two are not the only important cues.
3. ITD looks at the difference in arrival times of a sound's wavefront at the left and right ears.
4. IID looks at the difference in ampliture generated between the ears.
5. Sound is perceived to be closer to the ear at which the first wavefronts arrive. The larger the time arrival between the ears, the larger the ITD. This translates to larger lateral displacements.
6. And perceived lateral displacement is proportional to the phase difference of the received sound at the two ears.
7. But at 1.5 kHz, the wavelength is comparable to the diameter of the head, resulting in ambiguous ITD cues for azimuth. Not only that, but aliasing problems occur on 1.5 kHz and above, and phase differences no longer correspond to unique spatial locations.
8. Because of that, the ears begin looking for amplitude differences (IID) to localise sound in free space at 1.5 kHz and above.
9. So I was somewhat right in my first post on this topic! Yay! Normally I am shown to be wrong, so you'll excuse me if I'm jumping in joy here...
10. But since the duplex theory does not take into account how to localise sound on the vertical plane, then the theory needs to be augmented/perfected/polished/whatever.
11. Hence, HRTFs appear.
12. The thesis is too long to read, but I'll look at it in depth when I have the time.
So I think a friend of mine was right when he said that when tuning a system the presence of a body can affect the frequency response of a system. Assuming that the location of an RTA mic is made constant then the presence of 1 body would result in a different response compared to the presence of 2 bodies. And this doesn't even take into account the location (front, rear, driver, passenger side, both, all, etc.).
And another told me that 1/3 octave RTA is not sufficient enough, because when you see a flat or smooth curve on a 1/3 octave RTA you'd still find peaks and dips when using a 1/6, 1/12 or even 1/24 octave RTA.
And yet another told me that instead of having just 1 mic in aiding the tuning he would love to see a system where a mic array (or at least 2 mics) is used to get an average, complete response. If such an array is not available, the next best thing is to actually sweep the mic while taking a reading to get an average figure.
Question: has anyone gone to these kinds of extreme to just tune their systems?
Cheers,
Bon
