Full Version: idears for sq equipment and install
mojo the monkey
hi every body
im about 2 get a job [finaly] and im making up a list of equipment for my car
and thinking of diffrent installs that i can do for the boot and parcel shelf and
other places were stuff will go.
i want the system to be set up for sq comps and ill need a good alarm system
with central locking [sompthing i dont have atm]. with the install my car is
rather ristricted in boot room as so i wana try get
the most out of it :)but not over crouded. i want 1or2 12" subs in the boot
thanx allot jeff"
jimstr
dynaudio echo
you could do an install like in the dynaudio echo, with 8" drivers and an esotar tweater on the dash. running off an high end amp.
Mr_Bob
if you're looking to put an 8" in the console, you'll be limited to which drivers fit.
the Alto Falstaff 8"
blaupunkt overdrive (i think)
or
Phase linear aliante
for SQ the single sub upfront will be sufficient,
so i suggest you do a "streetbass" setup in the boot and disable it for SQ comps.
what's your budget?
mojo the monkey
well i dont rly know my buget every month im gona get a new part for the car so i dont want parts that cost over 1k exept for the amps
NISMOgemini
would a mid bass subwoofer in the console and the splits in the doors sound ok??
ie.. for the driver he will have more mid bass coming from the center of the car (his left ear) then the right.. throwing things out of wack..
or am i totaly wrong? :?
Mr_Bob
if it's under 150Hz, it won't matter much, and most splits will play nicely to 150Hz,
for SQ comps an 8" or 10" in the dash will work great, from 150Hz - 25Hz.
NISMOgemini
interesting.. cos i have to make a new console for my car (engine conversion and the gear stick is 6 inche back) so i might look into 1 or 2 8"s in the center
