Hi all,
I am ready to rebuild my front stage install and not sure which way to go. I have a bunch if Dynaudio drivers that I am planning to use.
I can have a 2 way front stage setup with 7" in the doors custom mounted on axis, and esotars in the kicks on axis.
I could use the 9.5" as midbass in the doors (slight angle or no angle), 5" and esotar in the kicks in sealed enclosures with enough internal volume. The kicks could either have next to no angle, or they could be on axis (this will be bloody difficult to do but maybe possible, however one speaker will to a degree block the signal path of the other)
I prefer a variant of option 2 (the three way stage), however it would seem that the most sensible way to do this would be with no angle on the speakers.
My question is basically would this sound any good or should I go for a more simple install while concentrating on good angling. Bear in mind that the kicks in my car are very forward and have good separation as the cabin is wide, but the seats are mounted closer to the tunnel than the doors.
The reason for trying the three way setup is simply because I greatly prefer having a good amount of up front bass being strong while not being overbearing.
I have seen and heard installs with both on axis mounted speakers and some with no angles at all, all of which had their merits, so I am just not sure which way will yield the best results.
Any help is greatly appreciated.
Thanks, Dan.
