I'm sure we have all heard variations on the theme:
A stupid man never learns from his mistakes. A smart man always learns from his mistakes. A wise man learns from other peoples mistakes.
While it would be preferable to experience everything, that is simply not possible in the real world. So in the real world, you have to rely on the experiences of other people. This is particularly evident when you look at the world today. It has obviously been shaped by people learning from the experiences of others. For better or for worse.... Secondly experience on its own is useless. It is how we use that experience. Likewise, the experience of others on is own is also useless. The key is, knowing how learn from your experiences and the experiences of others. If you were to use all of the experiences (of yourself and others) purely on face value, then you will be setting yourself up for problems.
QUOTE (Blackrazor)
Dan Wiggins of Adire posted a white paper some time ago showing the equation that defined transient response, and it turned out that transient response was a direct function of motor strength
Surely you jest?
(I do realize that it was probably just a typo
QUOTE (NUTTTR)
I have ALWAYS experienced that going from a 100wrms amp to a 200wrms amp sounds MUCH nicer, even with speakers that handle 80wrms at a maximum.... That's what i think.... anyone disagree?
Fletcher Munson curves anyone? Or less clipping?
QUOTE (Critter)
There is in fact NO absolute truth.
We have The Big Bang Theory.
Even Einstein produced the THEORY of relativity.....
Science and engineering never was and never will be a search for absolute truth.
What is important, is an effort to improve things in the real world.
Ok, so while you may use a cable, or an amplifier that alters the signal less, does it improve things in the real world? Can I/you actually hear the difference? Where do you draw the line? This is where science nd engineering comes in. By using a simple controlled test (with enough samples...) you can easily determine if you can actually hear the difference or not. Its up to you which is more important - the real world, or your imagination. In the case of selecting amplifiers, I prefer the real world (along with scientists). In the case of selecting (or producing) music, I choose imagination. Everyone has imagination, but it seems only those who have a vivid imagination are able to acknowledge the fact that imagination exists and solve any problems that may be caused by it.
Anyway, I would suggest that in the opinion of certain people, that almost all commercially produced amplifiers are overengineered, in the sound quality aspect - in that you cannot hear an audible difference between them. (once you match the crossovers and volume level..) This is purely based on the experience of all of those who have taken part in tests that control all of the variables except one - so the crossovers are matched, volume levels are matched and if one amplifier is much more powerful than the other, not driven into clipping. So the only variable is the "sound" of the amplifier, besides the effect of the crossovers on the sound, which could of course be tested separately. In the case of tube amplifiers, there is another clause - not all tube amplifiers are overengineered. Some have audible effects on the sound! However, based on peoples experience, this is usually not due to the fact that tubes were used at all. But simply that the damping factor was extremely low. So to account for this, a low cost resistor is used in series with the other amplifier to match this. They are not saying that amplifiers will not have some effect on the sound besides amplification. Nor that you cannot build an amplifier that sounds (audibly) different to another.
QUOTE (RTTZ)
Afterall, science has no emotion, music does...
Now there is a statement that could start an endless philosophical discussion......
