First off, scrub the plastic bit down with Prepsol (AKA Wax & Grease Remover)
Next, spray it down with Flexi Primer.
Once its dry, it'll look like this.
If the surface is a bit rough: put down a coat or two of Spray Putty over the primer. Once dry, lightly sand it using 600-800 grit Wet 'n' Dry for a smooth surface.
Wipe down the dried panel with Prepsol again.
Now put down the base coats. In this case, matt black.
The backing colour will effect the final colours appearance. Black gives darker results, white gives lighter. Experimenting can make for some cool effects & blends.
Once its dry, on goes the colour layer. In this case its a flip. Not much to look at yet.
Finally, when its dry on goes the clear coat. This makes the paint "pop" and gives it its gloss. Here it brings out the flip effect, the photo's dont do it justice.
Thats it ! Once the top clear coats dry its ready for action
Your new painted interior is heaps easy to clean, a quick wipe with a moist cloth is all it needs. Maybe some Meguires Wet Look on show day.
