Full Version: crossover vs cap for the tweeter
mk1982
hey i'm a bit new to SQ but looking at woofer response graphs i have an
idea to add $50 tweeters to a pair of Hertz ("Hi Energy - HV165") woofers
(off the popular HSK165 splits)
Since the roll off on many woofers occurs at 1khz i have considered adding
a cap to the pair of tweeters (first order, 6db) to protect them against
low frequencies at approx 2khz. this should allow them to operate over 2khz
while the woofer will naturally roll off at around 1khz ... if this is
successful will the result be similar to that of a crossover ? obviously
not. i believe this is the method coax speakers use however. so if i use a
resonable woofer (hv165) and a reasonable tweeter (eg. pioneer) with a cap
to limit the tweeter to >2khz will i achieve the result of a good coax
speaker ?
to put it another way ..
if you buy a new set of splits with crossover, and u throw away the
crossover and just use the capacitor for the tweeters ... how will the SQ
change ?
* what's the $#$%#@ address for the HERTZ website ? can't find it anywhere, response graphs for Boston RALLY NEO 3RD tweeters and Hertz woofers would be wicked smile.gif
Mr_Bob
the SQ will change considerably IMO.
the crossover is tuned to suit the speakers, and will often have appropriate slopes for the speakers.
if you run a 6db HP on teh tweeter, but nothing on the midbass, then the tweeter will be 90 degrees out of phase with the woofer.
it's not terribly hard to add a coil to the midwoofer too, how confident are you that the natural rolloff is at 1khz?
and what slope does it roll off at?
if you goto www.audison.it, click on elettromedia, it'll have a link to hertz in there.
icacha
Benny so the crossovers (12db) that I am building for Pete (Ultim8DTM5), another customer and myself for the ambient tweeters will be **** house? ahahahaha
9k up 12db down slope what you think?
oh just to add that these will be almost the size of a standard x-over and will handle over 100wrms smile.gif
Mr_Bob
depends,
do they contain impedance correction circuitry, as well as attentuation circuits, and crossover points and slopes that suit the driver, and keep them in phase for proper integration?
if you can answer yes to all of that, then i expect they'll be great.
jas
dont use a single series cap for these tweeters
there are very very very few tweeters that sound good with a 6db/oct x-over plus then you have power handling issues and x-over point problems. Look at the fs of the tweeter it really requires a very low fs to work well, from 700hz to 800hz is definitely preferred.
one of the very very few tweeters that work extremely well on a 6db/oct x-over is the dyn audio esotar. However even with this very high power tweeter (with very very low fs around 750hz) to make it work effectively and handle a lot of power the x-over point is from 4khz to 5khz...yes that high...and then the issue comes with what mid will be flat to that point..not many and you would require no more than a 5 1/4 mid but better would be a dome midrange unit to blend the stage together.
to make the tweeter go lower you require steep x-overs...not as you have tried to point out shallow 6db/oct x-overs. This will help with power handling and frequency response. For a 2khz point you would have to look at either an acitve 24db/oct on both 6.5mid and tweeter or a passive. This would give you similar power handling as a x-over point at 4khz with 12db/oct (which is an extremely popular setting for car tweeters & mids). Now here comes another problem. With such a big roll-off you require very careful aiming positioning of both mid and tweeter. It is important to position both mid and tweeter very close to one another to get a seemless front stage. 2inches basket to basket would be a limit with a 24db/oct setting.
in the end the stock 12db/oct standared x-over is a lot more forgiving compared to a 24db/oct setup. I think designing a new x-over is a lot more complex and could achieve better results after lots of listening and tuning the setup. Go for the almost plug & play 12db/oct standard x-over it will make life a lot easier.
STIK79
The phase "issue" occurs only around the xover point too (although it's much worse for 6dB because the phasal anomolies extend further around the xover point)
QUOTE (stik79 long ago in a far away forum)
Passive components alter the phase of a speaker around the crossover point - below i've whisked up a simple 6dB (albeit ideal) crossover with a simple 10uF cap and a 4ohm load (being our imaginary speaker) - this crossover has a -3dB point of about 4KHzish - has the following magnitude response
If we now look at the phase change at this point we see it's approx 45o!
Even at 20KHz there's a phase change of 11.5o
and finally at ~400Hz the phase change is almost 90o
However at this point the signal is so attenuated in magnitude that we really don't care (it's what -20dB?)
These phasal anomolies are more of a bastard when you're running speakers with different xovers (slopes/points etc) around the car - and even in crossovers some will HPF at 12dB and roll the LPF off at 6dB causing phasal anomolies around the xover point...
mk1982
damn that's a pretty full-on reply ! thing is i can't even tell much difference between focal splits on the GL Pro demo board smile.gif .. anyway mmm .. sorta lost for words there .. ok it will sound **** but
1) will it sound heaps better than not having a tweeter at all ?
2) isn't this exactly how tweeters are setup on a set of coax speakers ?
jas
yes in coaxial setups most cheap sets use the tweeter to extend the top end response of the speaker. they use the roll off the the mid and add a tweeter with a 6db/oct to extend the treble. These cheap ass "super tweeters" help but the result isnt all that great. I love the sound of well designed high quality spilt speakers..why would you want to down grade to that cheap coaxial setup level???
good coaxials use high grade tweeters and external x-overs with at least 12db/oct on the tweeter. Look at kef uni-qs, boston z, polk momo and lots more.
why would you want something thats well built to sound bad....just why????
