i thought this was a very basic excersize.. and read in the Tut' wish list thread that peopel wanted a basic into to fiber glassing.. so i hope this explains it enuff.
seen as the gemini kick is very basic iv just used the stock pannel, re created it on MDF and made my kicks from that..
if it were a newer car or and car with complex shapes.. instead of using the MDF base, i would have taped everythgin up and made a fiber glass bass to work off...
anywyas.. hope this is usfull for someone?
i tryed getting shots of every step but dad took the camera 1/2 way through. so i have the start and finish, with a bit in the middle missing
dynaudio 360 3 way splits.
stock kick pannel.. remove it
trace out the stock kicks on to some 3mm MDF
now trace out the rings for you speakers and cut em out.. in this case i have the 3" mid and a 1.1" tweeter (aswell as a 8" woofer that will be fit in the door cards).
if u want the speakers counter sunk, cut out extra rings slightly bigger than the speaker. this will alow the speaker to sit in inside
(can be seen here - http://www.caraudioaustralia.com/forums/at...ttachmentid=233
doing this will alow the speaker to sit flush or below the surface level on the pod)
now sit in the car and find out how u wanna position the speakers.. making up a frame like this and gluing it place with wood glue or hot glue gun.. it may take a few goes (took me 5-6) to get the positioning to how u want it.. try and aim the left kick speakers at the right head rest and the right kick speakers at the left head rest
now use a stretchy type flece material.. it dont mater what kind or colour.. (as u can see i used a pretty bear patterened material.. how cute)
stretch it over everything and glue it down to the rings and the back of the pod using spray glue (K&H is the best)
now iv used a layer of glad wrap under the pod here and screwed the 4 corners down to a scrap piece of timber(read scrape piece or timber is mums BBQ table
(NOTE: b4 screwing it down, make sure u cut of any large clumps of matiral stuck on the back, so that it sits nice and flat)
