Jan 22 2005, 10:32 PM
I have several test CDs and a pink noise generator built into my EQ.
Problem is, all the CDs and the EQ's pink noise all sound different....
I know it depends on the band filtering and coherent/non-coherent (incoherent? sic) but what is 'true' pink noise, and where does one get it from?
icacha
Jan 23 2005, 12:19 AM
on a light note, you can make it with your lips just say shhhhhhhhh
KAL SPL
Jan 23 2005, 01:50 AM
it plays every frequency between 1hz and say 25000hz , they are all recorded individually and played back at the same output level.
Well thats my assumption.
That way if a certain band is to low it will show on the graph as a low point.
Damon
Jan 23 2005, 09:01 AM
Don't compare pink noise tracks with your ears. Pink noise should be 20 - 20kHz of equal amplitude noise and when played back on a system will reveal frequency response anomalies - but you need to use an RTA to compare the tracks themselves to see any differences. ONce you have an RA you can plug your CD tuner's RCA directly into it and play each track to see what the true content is. Pink noise will give a flat response line.
Volenti
Jan 23 2005, 09:38 AM
White noise is equal power per frequency, pink noise is equal power per octave (or white noise with a 3db/oct low pass filter applied) which more closely matches how we hear sounds.
~Spyne~
Jan 23 2005, 10:56 AM
volenti is correct
but if u have a spare 1000 friends, my lecturer said that if u had 1000 people all in a room, all having different conversations at the same time, that is an EXTREMELY close representation of pink noise
got that many friends?
Jan 23 2005, 06:22 PM
not that many friends - I am too tied up listening to pink noise.
What I was trying to get at -
1. How can pink noise be the same if it sounds different?
2. Will I get different RTA results if I use different sounding pink noise?
Mr_Bob
Jan 24 2005, 09:08 AM
i've played pink noise, and i find that the RTA reading varies as the track plays!!
so i use a slower setting...
some RTA's have a pink noise generator, i'd use that one if you can!
Jan 24 2005, 04:47 PM
yeah, thought so
