Full Version: how good is flashtac ?
fatborry
just as the title says guys, how good is flashtac ? i am planning on doin my whole ute in it! takin out everythign and just going ballistic in it, would be heaps cheaper then any other brand name sound deadener, i plan to have EVERYTHING coated in it bar the roof.
let me know what you think and how much i should b payin for it..
TEGBOY
It was the flavor of the month, 6-12 months ago. Since the advent of G-Spot, bugger all use it.
I used it, and I now hate it, it fell off in all the areas I wanted it to stay, and is stuck with deft grip in areas I don't want....
Don't waste your time with it.
SirNemesis0
QUOTE (fatborry)
Are you sure? Measure how much you need and compare it to some better stuff (not extreme stuff). You'll get quite a suprise.
LexARSE
I think your better off spending your money on g-spot or dynamat or something and doing it properly. In the end you only get what you pay for and would need 3-4 layers of flashtac to get the same results as dynamat or something.
yeah, i think the dedicated namebrand stuff is better. but it's hard to know what suits your needs cos you may only need the lesser benefit of Flashtac, whereas g-spot/dynamat/etc may be overkill.
...although it's hard to go 'overkill' with SDer; you usually never have enough. :roll:
i've used Flashtac in some places in my car and it works well there (had no probs with it falling off either, but it's not in/on my doors or exposed to the elements; it's in my boot). but admittedly, i've used dynamat xtreme in the more important spots like my doors and find this stuff excellent.
so, 'some' is better than none, and if you're on a really tight budget, consider Flashtac. otherwise, if you can afford it, consider other products.
Shieldsy
If you have it use it.
i have used it and it worked ok.
does a good job of sealing doors.. but then again so does gaffa tape..
can't really see how well it works as a sound deadener.. adds some weight to doors and stops some of the vibrations. but might be better off paying more to make sure it will do the job completely.
