Full Version: DD C4 amp
TEGBOY
Has anyone had the chance to play with one of these amps yet?? I am looking to purchase a decent 4channel to run a set of Boston Pro splits and 8 RF door woofers.
I thought these looked good, because the variable x-over. Idealily I want to bandbass the door woofers.
I have about $800 to spend.. thoughts anyone??
Our C4 has a high pass variable from 50-5000Hz on two channels and a band pass variable from 20-120 HP, 50-5000 LP.
The channels with the bandpass are twice as powerful as the other channels, making it perfect for splits/midbass or tweeter/mid actively.
It's rated at 2x70Wrms and 2x140Wrms, but like all our amps it makes more than rated power (hence the 90A onboard fusing).
The C4 also has a remote level control with clip indicator, rrp $879.
Damon
That sounds like a pretty mean amplifier Phil. Maybe you should bring one down to Sydney when you come and see me next week?
It truly is a thing of beauty!
I put one in a Civic powering a set of Boston Pros and a 15", just a normal music system with a 4 ohm load on the sub channel. He won an SPL comp with 144.2 on Termlab! Crazy.
