Full Version: Advice for tuning Clarion DXZ925
findog
Hi guys,
I've had this head unit for a while, and had a play with the delay and parametric eq settings, but I got to a point where I was just making things sound worse, so I went back to no time alignment, and no equalisation. I have however got my levels pretty much spot on for the front, rears and sub. I have the front and rears on a 80Hz high pass (I have the choice of 50/80/120Hz on the HU). It definately needs equalisation to smooth out some issues with harsh treble, and hopefully more mid bass.
Now what, where do I start? My parametric eq gives 3 "bands" to play with for the front, and 3 for rear. Each band has a choice of frequency, q, and of course gain. The problem is I don't have the experience to know what freq i'm hearing problems with etc.
Would it be wise to make a test cd of tones, and using this get the response as close to flat as possible then tweak from there? Is there a cd i can get that will help me track down problem frequencies?
Also whats the best way to start tuning the time alignment? So far I have measured the distances from each speaker's sound path to my ear position which gave decent results, but are there general "rules of thumb" for adding more/less delay to say the rears or sub for example?
FYI this is what I'm running, in a 88 LD Astra / N13 Pulsar hatchback:
4inch Clarion dual cones up front off the HU, ie original factory ones =(
6inch 2way pioneers with horn tweeters on a very solid custom rear shelf getting 35rms each
12inch Shiva in sealed 1cubicfoot box running on 2x35rms bridged @ 4ohm
4x35rms alpine V12 amp.
All my levels are pretty much spot on, with only minor adjustments needed to the sub level gain on HU depending on the recording.
findog
B... Bu.... Bump
Alright long story short, any recommendations on a test cd that will help me flatten my frequency response (ie equal tones across the spectrum, so I can pinpoint peaks/dips)?
If not, any advice on software to create some test tones to burn to CD?
If u can be bothered to read the initial post, am I on the right track here?
