G'day first topic should have it in the right place and I searched but couldn't find anything on the Tru Technology T-6.500v2. I am trying to work out just which amp(s) I should run to get the best out of the audio gear I will be purchasing from Pyroay shortly; Pioneer DEH-P88R and DEQ9200 DSP with Focal Utopia 3 way front stage. Looking at adding a RE XXX or IDMAX 12".
Now I have an idea and would like to know if it's any good me being a car audio novice. Get a T-6.500v2, bridge it, run the Focals at 200W passive with the sub at 300W then when funds are available get a dedicated amp for the sub (Hammer? suggestions?) and run the Focals active off the T-6.500v2's 6 channels (each side 75W, 75W, 100W).
This idea any good? Other suggestions for amp(s)? Cost is not really that much of a concern as I am willing to sacrifice time for higher quality.
All this going in a R33 GTS-T
T-6.500v2
Channels: 6 CH
Frequency Response: 10Hz ~ 45KHz ±1dB
Rated Power: 14.4 Volts DC
T.H.D.: < 0.05%
4 Ohm RMS: 75W x 4 + 100W x 2
2 Ohm RMS: 125W x 4 + 150W x 2
4 Ohm Bridged: 200W x 2 + 300W x 1
S/N Ratio: > 100dB
CH Separation: > 70dB
Input Sensitivity: 0.16mV ~ 4 Volts
Damping Factor: > 400
Efficiency: 65.70%
Fuse Requirement: (3) 30 Amp
Power Supply: 11 ~ 16 Volts DC
High Pass @ 18dB / oct: 35Hz ~ 5.5KHz
Low Pass @ 18dB / oct: 35Hz ~ 290Hz
Remote Bass Knob: No
Bass Boost: No
Dimensions: (L x W x H): 21 11/16" x 10 5/8" x 2 3/8"
