TEGBOY
Nov 3 2007, 10:14 PM
Hi all,
I am chasing a set of replacment ambient tweeters, they need to be .75' in size.
The only company I can find is Rockford, and I want to have to go down that path, unless I have to.
They have to be .75, as I can't mod this panel anymore, as I can't replace the suede to match it.
So what's out there??
mooingchicken
Nov 4 2007, 01:17 PM
type x's are about that size arent they?
Timm3h
Nov 4 2007, 01:20 PM
The Pioneer TS-T15 is .75 inch, and I believe OZ make a 3/4 inch as well, but I dont know the model number, and I cant get on their site here
TEGBOY
Nov 4 2007, 01:29 PM
QUOTE (mooingchicken @ Nov 4 2007, 02:17 PM)
QUOTE (Timmeh @ Nov 4 2007, 02:20 PM)
Excellent thanks gents. I only really want them for RTA response.
The TypeX, sounds a good idea.
Luke352
Nov 4 2007, 03:48 PM
So are you after a .75" external dia AKA mounting hole size, or just a .75" dome, because there are lots of .75" tweeters but obviously there outside diameter is going to be bigger.
zion187reigneth
Nov 4 2007, 08:37 PM
boyd kevlars.............cors
TEGBOY
Nov 4 2007, 08:39 PM
No thanks, not a fan of Total Recoil.
They are only going to be playing from 17-20k, at -8dB or so.
Yes, they need to be .75O/D
ultim8DTM5
Nov 5 2007, 04:04 PM
Clint, try CDT Stage-up kit.
TEGBOY
Nov 5 2007, 04:26 PM
Oh yeah, CDT, forgot about them
I was looking at Rainbow's, unfortunately they only come in 25mm, need to do some more research.
Luke352
Nov 5 2007, 04:29 PM
QUOTE (ultim8DTM5 @ Nov 5 2007, 04:04 PM)
HAHA, thats the first thing i thought of, checked them though and they are to big.
Matt VIP
Nov 5 2007, 04:58 PM
TEGBOY
Nov 5 2007, 05:17 PM
Nice JL's will have a think about them.
ultim8DTM5
Nov 6 2007, 03:26 PM
QUOTE (Luke352 @ Nov 5 2007, 05:29 PM)
Thought my ones were .75 then again was a few years ago. Sold them for $50 too.
TEGBOY
Nov 6 2007, 03:37 PM
Damn it Pete.. I would have snapped them up!
Luke352
Nov 6 2007, 05:47 PM
Yeah the CDT is a .75 but that is the tweeter dome, or that is how I read it, and if so the cut out hole would likely be closer to 1", but it may be worth shooting them an email and checking. I'm probably wrong lol...
ultim8DTM5
Nov 6 2007, 08:31 PM
QUOTE (TEGBOY @ Nov 6 2007, 04:37 PM)
I can't help it if you're always two steps behind
TEGBOY
Nov 6 2007, 09:09 PM
Oh hahahah
zion187reigneth
Nov 6 2007, 09:34 PM
tegasaruos`~question~ i cant hear above 16k , is your idea worth doing?............cors
TEGBOY
Nov 6 2007, 09:46 PM
QUOTE (zion187reigneth @ Nov 6 2007, 10:34 PM)
Cory, its only for RTA.
Nov 6 2007, 10:45 PM
What's the OD of the mounting hole?
Nov 7 2007, 08:56 AM
thats cause your old, your hearing is damaged from riding motorbikes
read about freq 20k+ somwhere else on this site for more info
TEGBOY
Nov 7 2007, 12:21 PM
QUOTE (DD Phil @ Nov 6 2007, 11:45 PM)
Phil, the OD of the mounting hole is 35.2mm Or roughly 1.5"
I have attached a few pics of the pods.
The mounting hole is quite a decent size, but once I use the tweeters flush mount kit I am limited. I have tried a set of Boston Pro tweeter flush mount brackets, and they don't fit.
I think this why I am limited to a .75" tweeter, once the mounting cup and all are attached, then it its a pressure fit.
Matt VIP
Nov 7 2007, 12:27 PM
what about finding the tweeter you'd most prefer to use, and not using the flushmounting kit? just the tweeter by itself? then use another form of attachment (silicon at the back, or around the edge) to hold it in place?
btw, I got those Oz tweeters to try out as ambients...never done this before, so if I dont want/need/like them you can have em
TEGBOY
Nov 7 2007, 12:33 PM
QUOTE (VIP318 @ Nov 7 2007, 01:27 PM)
Bro that would work, but I am stickler for neatness, I can't have exposed edges visable. The flushmount kits are the best way to finish the tweeter mount off.
I rag on people who half finish things and leave ratty edges, so I couldn't do it myself
THanks the offer of the Oz, let me know
Luke352
Nov 7 2007, 04:01 PM
QUOTE (TEGBOY @ Nov 7 2007, 12:21 PM)
Now you say that, thats what I was asking before and you said the hole was .75" or rather thats how I interpreted you.
The CDT's will fit along with countless other tweeters.
When I get home I'll post links, as I found lots earlier that would fit that size hole.
QUOTE (TEGBOY @ Nov 4 2007, 08:39 PM)
^^^^ Thats what confused me.
ultim8DTM5
Nov 7 2007, 07:08 PM
Ah leave him alone, people who suffer from ATD are a dying breed
TEGBOY
Nov 7 2007, 07:39 PM
QUOTE (Luke352 @ Nov 7 2007, 05:01 PM)
FFS, I made a mistake, I didn't have the car, to measure the hole when I posted. I could only go off the size of the previous tweeters, I had which were .75".
Hence why I updated once I knew.
Sorry!
Luke352
Nov 7 2007, 09:26 PM
Ah ok, sorry I didn't mean to come across like I was having a go at you, I was just kidding around
, your system and car sounds like it will be very nice, so I'm keen to try and help you find some different options
I remember seeing some tweeters that had cutouts around that size I'll link them when I get home from work.
Luke
Luke352
Nov 8 2007, 01:15 AM
Luke352
Nov 8 2007, 11:27 AM
Then if your after a cheap easy solution which as you say it's only for the RTA then these should do the job perfect
http://www.madisound.com/catalog/product_i...roducts_id=1767 apparently they also sound quite nice when crossed quite highly, the frame size is 39mm so at a guess I would say the coutout needs to be about 34-35mm.
Dayton also have a version of the above tweeter, 4ohm higher sensitivity etc... go here and scan down a bit,
http://www.daytonaudio.com/loudspeaker/drv_miscdrivers.html they can be sourced from here
http://www.darcheraudio.com.au/
TEGBOY
Nov 8 2007, 07:58 PM
Thanks Luke. The Alpines or the JL would be a great fit.
zion187reigneth
Nov 8 2007, 09:11 PM
QUOTE (Fudd @ Nov 7 2007, 09:56 AM)
im happy that im 28.
not happy about the hearing though............cors
