Full Version: SQ 4 ch amps under $1200
skitzoman
recomedations please,
running 2 IDQ 12 & 6" splits
my short, short list
JL A4300
Audio System F 4 600
rockford T 600.4 ( more ballsy i know but like the rockford amps )
philz
From the other thread you made.
Audison LRX 4.1K, or 1.3k
OR
DDs4
The amps given are nice, but may not be "enough" power for the subs, when you want to "crank it up"
RMA
The Audison amps quoted by philz are all 2 ohm stable running subs.
skitzoman
thanks for the feed back
i have checked out the audison web site
but the dds4 ? - can you give some more details or a link
ps the audison amps are sexy looking beasts what are the prices
Louie
~ $800: Audiosystem F4-380, Alpine MRV-545; Eclipse XA4000; Rockford T400-4
~ $1000: Audiosystem F4-600, Audison LRx4.5, Audison LRx4.1k, Boston GT40, DD S4, Alpine PDX4150, Treo SSX AMP 75.4, MB Quart PAB4100, Rockford T600-4
http://www.ddaudio.com/dd/amp/amp.asp?series=S%5dDD%20S4%20link" target="_blank">http://www.ddaudio.com/dd/amp/amp.asp?series=S]DD S4 link
I wouldn't recommend that JL amp for SQ, nor the Rockford. The Audiosystem I don't know much about but from what I've heard they're ok.
also, you won't get much sub power from a 4 channel. Better to get a 2channel for the front and a monoblock for the sub.
skitzoman
thanks louie
who sells Audison and/or Audio System in Brisbane
skitzoman
QUOTE (Pulse-R @ Nov 25 2007, 01:40 PM) *
i have small foot print to mount the amps hence the 4 ch
i can fit two rockford amps on the rack t500-bd &t400-2 but price starts to become a issue
mooingchicken
northfield moorooka stock audiosystem. and they would be able to order in the audison.
only place i know that stocks audison in bris is autobarn capalaba, but i have only seen there entry models there.
RMA
QUOTE (skitzoman @ Nov 25 2007, 02:02 PM) *
FHRX have the price lists for most brands on his web site.
GSN03
the dd s4 is very nice sounding amp
muzzy66
On that budget, I'd be looking at:
* DLS Reference RA40: 4x75 - $849rrp
* Focal FP 4.75: 4x75 - $899rrp (old price, may have changed)
* Phass AP 4.65 - $1,099rrp (assuming they are still available)
* Vibe Blackbox III: 4x100 - $1,025rrp (assuming still available)
* Rainbow IPaul 4.300: 4x90 - (contact mobile fidelity for pricing, as I'm not 100% sure)
Also, have you considered a three channel? If you can wire the subs to present either a 4ohm or 2ohm load (which you should be able to do one or the other), you should be able to get decent output from the sub channel.
Something like:
* DLS Reference RA30: 2x70 + 1x265 @ 4ohm (or 1x365 @ 2ohm) - $899rrp
There are also some nice 5 channel amps out there (including from Focal and DLS) around that price point.
QUOTE (skitzoman @ Nov 25 2007, 01:02 PM) *
The S4 is an asymmetrical amp, rated at 2x100W and 2x200Wrms.
Typical applications include:
Fronts 2x200W, rears 2x100W
Tweets 2x100W, mids 2x200W
Mid/Tweet 2x100W, midbass 2x200W
Fronts 2x200W, sub 1x350W
Fronts 2x100W, sub 1x700W
It has on board 24dB/oct bandpass crossovers, variable from 50-5000Hz.
It's a true "high end" design, using high spec parts and construction.
As Geoff mentioned, his Polks sound much nicer with the S4 powering them than the Alpine amp it replaced.
