Hey frantic,
Im a french car fan, ( and former owner). I know how much fun they are to drive. having said that the 206 isn't the best car audio platform, but its definately improvable.
QUOTE (FrAnTiC @ Dec 10 2007, 11:48 AM)
G'day guys,
I've been looking around for a while and i'm trying to spec up a new system for my Peugeot 206 (05 model).
So far i've only figured out the following:
+ Headunit Alpine CDA-9887
http://www.alpine.com.au/products/product.asp?modelID=291+ Speakers Hertz DSK 165
Not much i know, I just haven't had the time to make a trip to a car audio speciallist.
A couple of notes...
+ I know I can't integrate the LCD display and control stalk, either can't get the adapter or too expensive ($300+)
- Well several 206 owners I know have intergrated it, so it definately possible. Don't settle for $300, get better quotes. (im assuming $300 for the adaptor on its own?)
- If $300 includes a budget H/unit and you think thats too much, then you need to save more money. As 206's benefit greatly from a good head unit & lots of sound deadning.
+ Everything is stock at the moment
+ Have had factory installed rear 6x9 in the parcel shelf, not sure what brand.
- 206's don't have 6x9s in the back their an odd size. Leave them runing of the headh unit. Concentrate on you front speakers.
+ Not sure on budget at the moment but I'll try to figure it out. I don't want to spend too much but I would like something decent.
$200 to $400 on H/U
$400+ 4ch amp (seems like a lot but amps make a big difference and good for future use)
$250+ front splits.
$150-$200 in sound deadning - 206's are rattly little cars. (I know first hand)
$300-$400+ installation. A good install will make all the diference, even using factory equipment.
If money is tight, buy the best you can afford, one at a time.
Eg, the best headunit you can afford now... then save up.
Then the best amplifier you can, save up
then the best front splits you can, save up
then sub etc...
The other option is to consider 2nd hand. Theres bargains to be had.
+ Not sure if I need an amp or not but I would be grateful for recommendations
- Its always a plus.
+ Considering a subwoofer but I would prefer the boot space. I need to talk to a car audio specialist and see if there are any options to do a discrete install. Otherwise is there an option to utilise speakers for a bass replacement?
- Buy a 4ch or 3ch amp now, upgrade to sub later.
+ Anything else you might think i should consider...
Sorry to sound like such a noob but I would be grateful for any advice you could share...
Were all here to help each other. So im sure other will chime in. Good luck.
