Anyway i have a new plan. And this is where i need a little advise. I plan on Using the wheel well as the encloseure, glassing it and building a baffl on top. My only cncern is if there will be enough volume and how i would go with porting it.
Anyone have anyidea if there will be enough volume in the wheel well? (I dont want o fill it with sand or water if i can help it) I need 106.4L
In regards to the port, anyone have any ideas for this, will the odd shape of the enclosure make it difficult?? Anyone have any cals to help me out? The manual suggests a 4" 101mm Long
I will be running the sub inverted.
I am running a Fusion NV- Sw15
Heres the T/S
Max Power Rating (Watts): 2500
RMS Power Rating (Watts): 1100
Coil Height (Hvc): 40
Compliance (Cms): 146.18
Cone Area (Sd): 77.93
D.C. Coil Resistance (Re): 0.88
Electrical Q (Qes): 0.552
Force Factor (Bl): 8.4
Free Air Resonance (Fs): 23.62
Frequency Response: 19Hz - 500Hz
Gap Height (Hag)(mm): 10
Impedance (Nominal): 1
Inductance (Le) (mH): 0.51
Linear Excurson (Xmax): 40
Mechanical Excursion (mm): 15
Mechanical Q (Qms): 6.17
Moving Mass (Mms):285.85
Sensitivity (dB) (1W/1M):87
Total Loudspeaker Q (Qts):0.506
VAS (L): 126.07
VAS (CuFt): 4.45
Magnet Structure (Oz): 308
Total Loudseaker Displacement (L): 12
Garrett
