Hey guys, a few weeks ago my mate came to me with an old Jaguar, cant remember year or model, but it had a 12v positive ground system (meaning chassis is at + potential)
This also meant I couldnt just wire in a standard negative ground head unit for him the normal way, and I also nearly told him I couldn't do it, but a bit of quick thinking and I changed my mind and said no worries.
Here's how to do it
You will need:
-standard 30A horn relay
-relay base
-the stereo
-required connectors or solder and heatshrink or whatever
Here goes:
Connect Yellow wire of stereo (Battery +) to the chassis with a ring terminal to a clean point as you would a ground wire.
Connect Black wire of stereo (Ground -) to the battery - feed to the ignition switch using a 10A fuse at the splice.
Connect Red wire of stereo (Acc +) to terminal 87 of the relay
Connect Terminal 30 AND 86 of relay to the chassis with a ring terminal and 1A fuse at the chassis
Connect Terminal 85 of relay to car harness negative acc power wire.
The stereo should now work as it would in a negative ground car.
Attached is a diagram
Hope this is of help to anyone
-Ben
