OEG50
Mar 7 2008, 07:26 AM
Disclaimer: The following is provided as a GUIDE ONLY, and neither myself nor MEA take any responsibility for the outcomes of someone else doing the following. You follow these steps at your own risk!
Aim: To quieten tyre noise
Required:
Wax and grease remover
Brush on sound deadener (4L drum is heaps enough to do all 4 wheels)
paint brush
srcubbing brush
plenty of rags
jack and car stands
Steps:
jack the car up. make sure the weight is held up by stands not the jack.
remove wheel.
there will be years of dirt and tar etc built up one the arch. this will all need to be cleaned off with a good scrub and wax and grease remover.
once the bulk crap is of and you see the paint give the paint a wipe with a clean rag and wax an grease remover to remove all the residue.
then cover your brakes and suspension with rags to stop any drips from falling on them and paint away. start with a thin coat and build it up as thick as possible. a layer 3-4mm is easily obtained.
do the areas of the arch that are between you and the cabin. no use deadening the engine firewall etc.
Other comments:
This difference was instantly noticeable! almost no tyre noise! definately worth the 40 bucks for the deadener!
bmroxm5
Mar 9 2008, 08:59 AM
'Brush on deadener' is this available at repco/bunnings?
Are there better brands than others?
_Anthony_
Mar 9 2008, 10:36 AM
QUOTE (bmroxm5 @ Mar 9 2008, 09:59 AM)
I'd doubt you'd need it for your E class Stu
http://www.mobileelectronics.com.au/forums...00&hl=brush
mad89
Mar 9 2008, 11:35 AM
You can also do the same thing with spray on, for a similar effect. Its just a little easier IMO.
Nice write up anyways mate.
s4turn
Mar 10 2008, 09:56 AM
have you noticed much difference with road noise?
bmroxm5
Mar 10 2008, 06:43 PM
QUOTE (_Anthony_ @ Mar 9 2008, 11:36 AM)
haha you can never have enough deadening! or you can never have enough silence? i checked my wheel arches the other day and it looks like they already have some sort of thick black stuff on it that might be deadener... or dirt.
OEG50
Mar 10 2008, 08:49 PM
i thought mine had something on it too! turned out to be dirt lol got it back to all paint. Super cheap sell a brush on deadener for 40 something bucks. this is what i used
Click to view attachmenti don't think the brand etc would really matter cos its all about adding weight to that panel which they all do. this stuff takes a long time to dry so wait a week before applying the next coat. i will be doing another coat whenever i get time down the track. the spray stuff is just easier the paint on is more cost effective and more effective cos thicker coats can be painted on.
the difference made was instantly noticeable and for you guys that know my car and all the dynamat etc in it for something as simple as this to make a noticeable difference it would be unreal in a stock car (not big luxury boats that alread have heaps). a definate must do for those wanting a quieter ride!
Mar 11 2008, 08:57 PM
hmm, i wonder if this stuff would be too thick for a spray gun
OEG50
Mar 11 2008, 10:09 PM
sound off make a spray gun one
TheDiko
Apr 14 2008, 10:48 AM
QUOTE (OEG50 @ Mar 10 2008, 08:49 PM)
Does this mean no driving for a week?
OEG50
Apr 19 2008, 10:45 PM
no it sticks still no worries driving but if you press it it is still soft and as id feels tho the inside is still goey. wait till it is completey hard before reapplying another coat. i drove the car less than a hour after doing it. in my old ek i did it then that day i drove in rain. it still stuck but had water rippled effect on it. it doesn't take long for the air exposed surface to dry and create and skin over the still goey centre. once the skin is formed tho it takes a long time, week plus for really thick parts, to become hard.
i will be doing another coat for over kills sake. i've went overkill everywhere else with it so far but am thankful!
RoVer™
Apr 20 2008, 09:10 PM
Very nice write up!
Definately will be trying this.
I'll probably be doing the VS and my bro's EK. As you might know, EK's (civics in general) are a moon away from quite
There isn't deadener anywhere yet except flashtac on the number plate and some on the boot lid.
~Sparkles~
Apr 21 2008, 01:18 PM
you can get spray guns for bitumen paint - they go on flee bay for about $10+ p&h
or if your mechanic is also a panel beaters work shop like mine - just get them to apply it when tis on the hoist
RoVer™
Apr 22 2008, 03:42 PM
Did the civics boot and all wheel wells today. Now sound is coming from underneath and the firewall
thorpef1
May 23 2008, 03:36 PM
Sounds like a uni break job.
Will deff give this a go when i get time.
bobo333
May 26 2008, 07:34 PM
would this be suitable to do other parts of the car too, ie. doors, floor, boot lid etc, coz im guessing this would be a lot cheaper than dynamat or similar, also how would this compare to decent matting in terms of sound?
thorpef1
Jun 2 2008, 03:02 PM
Would be good if we could. i would probably do the boot aswell.
OEG50
Jun 4 2008, 10:20 PM
this stuff in comparision to the matted stuff like dynamat etc is just as good but alot harded and messier to apply. what deadens the panels is weight, so per weight it is just as good but i would prefer the mats. Deadener makes the panel more weighted therefore has more inertia and harder to vibrate, is more solid. in addition to this, the tar based deadener absorbs the sound energy and turns it into heat.
i would avoid using this stuff inside the car as it STINKS for weeks.
i would recommend for in the boot you do what i did
my bootpaint the boot with PLENTY of deadener. whilst wet carefully cut pieces of the fleece matting to shapes to cover the boot completely. give the matt a good squish down. and it will be stuck!
Enjoy!
bobo333
Jun 5 2008, 11:03 PM
cool, i think il be doing the boot this long weekend so il head down to supercheap and grab a big can of that deadener to go in while im there...
Jul 16 2008, 12:05 PM
It's commonly thought that adding weight is the only thing about a sound deadener that helps reduce noise.
It's also wrong.
Dynamat extreme ways much LESS Than most bitumen based deadeners, but dampens much BETTER.
blanketman
Jul 16 2008, 03:57 PM
also if you want to reduce road noise
use the felt stuff also
name has left my head
Jul 16 2008, 07:58 PM
actually i believe theres some new products out, air cell foam with a solid layer on top very much like dynamat. Theory being the air cell seperates the floor pan from the solid stuff, so it doesn't vibrate so much as reflect the noise. Cheap too.
_Po_
Jul 16 2008, 10:26 PM
I did my rear wheel arches the other day. They're open to the "cabin" of this small 2 seat hatchback, and the front arches are in the engine bay so I didn't do them.
It made a big difference. Even driving slowly on grass the difference in noise was obvious on the first drive. I really wasn't expecting such great results. On the road it was much much better. Previously the majority of the road noise came from the rear of the car but now it's all at the front (firewall, floor, doors).
Like people have said before, sound proofing never ends, once you stop one noise you notice another.
blanketman
Jul 17 2008, 09:23 AM
Quid
where did you find this out??
sounds interesting
devolutionary
Jul 17 2008, 11:51 AM
This seems to be a good, rather cheap and easy step to reduce road noise.
Good post!
Jul 19 2008, 12:51 AM
found what looks like the patent, still trying to find actual product.
edit : here we go
http://www.cascadeaudio.com/car_noise_cont...ar_barriers.htmhaven't found much feedback yet though, but the theory is interesting.
edit edit : patent, european at least..same business.
http://www.freepatentsonline.com/EP0951406.html
raddeal
Jul 20 2008, 09:03 PM
QUOTE (Liquidity @ Jul 19 2008, 12:51 AM)
edit : here we go
<a href="http://www.cascadeaudio.com/car_noise_cont...ar_barriers.htm" target="_blank">http://www.cascadeaudio.com/car_noise_cont...ar_barriers.htm</a>
http://www.freepatentsonline.com/EP0951406.htmlsame STC as cascade's VB-4 sound barrier
here
