QUOTE (~thematt~ @ Apr 7 2008, 11:09 PM)
I'm not bothering to even try, at the moment. Later on, I'll skip stereo and aim for Ambiphonics or Vector Based Amplitude Panning from a carputer. My guess is you're doing the same?
For others think of it this way. What is the stereo effect? Not stereo as in 2 channels of sound, but the ACTUAL effect.
Its an effect that produces a wider and deeper stage then the speakers. It eliminates the speakers from the reproduction (aurally). It achieves this by two ways. One is the individual channels of information sent via the transmission media. The other is by forcibly setting up enough crosstalk to force a phase change as the wave moves around your head.
For a full 180 degree soundstage (real stereo), you need all your speakers in the same field (near/far) and at 120 degree azimuth. This is the only way you'll be able to pull the phase as the wave moves around your head. Given that most cars dont have their speakers at even CLOSE to 120 degrees of azimuth, you'll never get that phase change. And therefore, you'll never get that stereo effect. It takes a LOT of processing, fantastic interior space and a little luck to get even close.
Thats why 'old Abmo keeps referring to Monophonic Panning. This effect is basically having the speakers at the extremes of the stage, and the image spilt open between them (sound familiar, anyone?). There was a fantastic thread on EliteCar a few months ago on it, quite good.
Basically, stereo requires similar reproduction space to the recording space, because it doesn't deal with this (and hence in an environment where the space has a MAJOR effect on the effect, it simply doesnt work). More effective methods, like Ambiphonics and VBAP, actually deal with the reproduction space, and therefore are more effective.
my setup is a bastardised setup using ambiohponic principles. basically, i use the RACE program to eliminate crosstalk, but at the same time dont have the speakers directly ahead. ie, my setup will remove (assuming perfect radiation from the drivers) the crosstalk electronically, but i will have to compromise on the HRTF due to the speakers not being directly ahead.
of course, the image wont sit on the centre of the bonnet, but sit directly ahead of the driver and the driver will be sitting in the very front seat. but at least there will be an image.
i haven't tried this setup in car very much. it seems to work with my $20 computer speakers (i was surprised, as i thought i would be sitting to close), but whether the early reflections and combing will kill it in car, i simply dont know.
