antVT
Aug 16 2003, 06:20 PM
Hey all. I have just purchased one and have a question regarding the auto gearbox.
Should the auto box be in 4th at 80km/h? Mine stays in 3rd till 90-100km/h. Its on just under 2000rpm at 80. Is this right?
If this is not right, what could be the problem? Any help appreciated. Cheers, Ant
antVT
Aug 16 2003, 06:24 PM
Also, can a boost gauge be wired to the factory s/charger as im curious how much boost it makes. Also what is water injection and how does it work? Cheers, ant
IvanTheTerrible
Aug 16 2003, 10:04 PM
80-100kmh is high but they have an electronic box so there might be another reason. Boost guage can be included if you can find a pot into the inlet manifold after the blower. Water injection reduces detonation under high boost.
hsv2000
Aug 16 2003, 11:20 PM
iirc. stock boost for a s/c v6 is 6psi?
XHELL
Aug 17 2003, 01:03 AM
Check your not in "Power" mode.
If your accellerating through those speeds then it won't select 4th until you level your speed off. Does it go to 4th cruising? and traction control suks in these things cos if you boot it, it feels like the computer knocks the cylinders out too aggressively and really bogs down for awhile...
I thought the boost was only around 4-5 psi, I guess 6 makes more sense due to the power output from standard.
For around $4k you can buy a kit which ups the power output to around 20kws @ the wheels.
antVT
Aug 17 2003, 12:32 PM
thanks for the replies. Ive tried with power mode off and on, most of the time its off, and it still sits at just under 2000rpm (1700-1900rpm). Dont have traction control, and it maintains just under 2000 whilst cruising with and without cruise control on. When cruising at 80, and I manually move the gear selector from D to 3, nothing happens -ie revs dont change. I just upgraded from a VR V6, and i know 80kph in that was well under 2000rpm, but im not sure if this one should be the same or not. Thanks, Ant
Super SS
Aug 17 2003, 03:57 PM
The auto will have trouble changing into 4th at 80 (it will do it at about 85 usually) its to do with the shift points Holden programed into the PCM. at 100 cruising in 4th you should be 1800-1900. If you want to fix this you need to get the shift points programed with Kalmaker. You can have normal mode for cruising and power for traffic light duals (trust me, much much more fun).
goto
http://www.v6supercharged.com.au for mods. My car is the first one on the pictures page and all the vids are of my car. PM me if want any info about super 6.
And with the boost guage you hook it up to the vacuum line that goes into the boost bypass valve (take off engine covers and its the black circular thinggo in front of the bend at the back of the blower next to the throttle body)
Redav
Aug 17 2003, 06:07 PM
Sounds like it isn't going into 4th. The auto gear ratios haven't changed between the VR & VT, (www.carsales.com.au). So if you're saying there's a rev difference between the two models at the same speed then you've got either a problem with the gear box, (or it's not ready to hit 4th as per Super SS's post), it's had it's gearing reworked or it's had a different diff installed.
Cruise control, power / economy modes and manually shifting the gears won't change what rpm it does at a given speed. Also, I don't think the auto lets you select 4th manually, does it? Pointless if it's an overdrive ratio when 'D' will select it for you.
Redav
[white lie]
Aug 18 2003, 03:21 PM
Power mode will effect its gearing (ie what revs its doing at a certain speed). The power mode in the 4L60E boxes draws the revs out and definately hangs onto 3rd a lot longer. It wont tend to change up from 3rd if in power mode until around 85-90km/h.
Also, I do believe the gearing was changed in the super 6's. They stayed the same from VR to VT with the N/A varients, but the super 6's would of got a revised shift pattern to increase performance slightly.
If its really bugging you that much, take it to a decent EFI Tuner. They'll be able to reprogram the shift pattern and make it drop into 4th a lot sooner...while you're there you may as well get the "power mode" beefed up so it shifts faster and firmer like SuperSS's box
Redav
Aug 18 2003, 03:41 PM
[edit]
It can change what gear you are in at a specific speed which affects RPM but it won't affect what RPM it's doing at a certain speed for a given gear. That's a fixed ratio that requires gears being changed in the transmission. Power mode will only change the RPM at which it changes gear therefore will hang on to a gear longer, as you mentioned.
[/edit]
There's a chance that carsales.com.au isn't correct however I've always found it to be pretty faithful and it shows the same ratios.
Redav
[ August 18, 2003, 20:23: Message edited by: Redav ]
Super SS
Aug 18 2003, 09:43 PM
all Super 6's have 3.08 gearing and power mode will effect what gear you are in at a certain speed/load therefor your revs can be different
and the shiftkit also helps a little with the firm shifting
Redav
Aug 18 2003, 10:08 PM
Sorry, wasn't clear. Power mode doesn't change the RPM in a gear for a specific speed.
i.e. if it does 80kph in 3rd at 3000rpm, the rpm won't change whether you're in power or economy mode.
[reworded previous post]
[edit]
Actually, by the looks of it all automatic VN - VY, V8's and V6's have the 3.08 gearing.
[/edit]
[ August 19, 2003, 09:20: Message edited by: Redav ]
Super SS
Aug 19 2003, 12:58 AM
all auto's have 3.08, manuals are 3.45, clubby R8 are 3.73 and the GTS is 3.91 (clubby and GTS only apply to VTII onwards)
sikvw
Aug 19 2003, 02:31 AM
Remember that something as simple as different tyre diameter will alter your cars final drive ratio.
[white lie]
Aug 19 2003, 05:07 AM
I understand what you mean about keeping RPM constant in the same gear, but from what I understand from the original post, its not kicking into 4th/overdrive...
I would assume the diff ratio is the same, but since the box is entirely electronic, i believe that they have a different shift pattern, which only puts it into 4th gear closer to 90km/hr where as N/A varients will happily go into 4th around 75km/hr
Redav
Aug 19 2003, 11:17 AM
Yeah, agreed. Yeah, that's true, sikvw. Doh, I meant non HSV autos only, damn, I keep missing the last detail. I'll fix that.
[ August 19, 2003, 11:28: Message edited by: Redav ]
BlackIce
Aug 19 2003, 05:15 PM
1,800RPM cruising is pretty much what the gearbox is programmed to do.
It will try to cruise @ 1,800RPM no matter what speed you do. Cruise along at 60km/h you'll notice it doesn't engage 4th gear at all, but hangs around the 1,800RPM mark.
Try cruising at 75km/h over a slightly undulating road, the gearbox will pop in and out of 4th as it gets confussed about whats going on and tries to maintain 1,800RPM . Annoyed the Hell out of me when I first got the Statesman.
Boost gauges arent wired in, they run off a vacuum tube. Super SS's idea is a goodun. I've contemplated fitting one, but dont want to spoil the Stato's interior looks .
Water injection squirts a fine mist of water (like fog) into the intake. The idea being it cools the intake charge. Cool air = denser air, which = more power. Also when you start upping boost the compression of the air causes it to heat, which in turn harms power or causes detonation (which harms engines). Water injection cools it down etc etc.
Stock Boost is 6PSI.
And finally.. I dunno about everyone elses ride, but if you muscle the Statesman off the line she's more interested in turning the rear Toyo's into clouds of smoke, so you can't be too excitable off the line.
Redav
Aug 19 2003, 06:59 PM
Is there a reservior for the water injection that you have to keep an eye on?
[white lie]
Aug 20 2003, 04:48 AM
yep...just fill it up every time you fill up with fuel and you'll be fine
BlackIce
Aug 20 2003, 12:21 PM
Most systems patch into the windscreen washer bottle. Which is cool in something like a Laser TX3 Turbo Ghia 'cos they've got a "Low Washer Fluid" level light in them .
As far as I know the only water injection systems are aftermarket ones, no company fits them as standard.
Trivia Time: Holden considered upping the boost on the VL Turbo's & adding factory water injection but canned the idea as they figure (quite rightly) most lazy bums wouldn't bother filling the resevoir and the engine would ping to death.
Oh, and water injection is not the same as intercooler spray.
Super SS
Aug 21 2003, 10:04 PM
Im getting H20 injection on mine when I get it retuned after the cam install (in a couple of weeks). Just dont go to stupid with the water or you will remove the teflon coating on the rotors (also no methonol mixed in to the water).
Whitey Ford
Aug 22 2003, 05:30 PM
Water injection is used to cool the intake air and is found on many prop powered military planes (not jet powered, obviously). Works in a similar fashion to an intercooler, but it's impossible to intercool a supercharger that sits in the valley of a V8 and blows directly into the intake manifold.
As a result, it does prevent detonation as a side bonus.
the[K]id
Aug 27 2003, 04:46 PM
Not impossible
The US boys have a water intercooler than sits inbetween the inlet and the blower for the super 6. Of course it lifts it a little, but like those guys care about a little bonnet denting...
MrMonaro
Aug 27 2003, 05:50 PM
Its not from the US, read this months issue of streetmachine.
slodki
Aug 27 2003, 05:58 PM
Sorry to hijack the thread
My mate has a '98 VT, looks the same as in the vids that Supper SS posted, and i was just wondering would it be possible to put the same supercharger system onto his engine??
Is is possible to turn that VT into a 'normal' supercharged V6 VT?? And also what i read on the website (
http://www.v6supercharged.com.au) was that with superchared V6 they had some sort of air hose which was used when just cruising, thus not using my fuel, but when stomping on the pedal, it would use the supercharger...
Would something like this be possible as well?
Sorry if this is a noob question, but i only just started to get into this kinda stuff..ohh and one other thing...is a nice big turbo possible in this car as well?
[white lie]
Aug 27 2003, 08:42 PM
If you want to bolt a factory Holden supercharger onto a normal ecotec engine, no it wont work. There are a lot of differences between the supercharged motor and the N/A one. If you want something that looks factory, get hold of one out of a wreck and put that in, otherwise there are a heap of aftermarket setups/kits available.
CAPA are probably the best known for S/C setups on commodores, but STA also do some good work.
Turbo's are possible on any car, it just depends on the amount of work (and money) you're willing to do. A twin turbo setup using something like twin GT25's would be perfect for the 3.8L 6's
Super SS
Aug 28 2003, 01:50 AM
To put the m90 on na 6 you will need the super 6 inlet manifold, heads, fuel rails, injectors, fuel pump and blower of course as well as computer retuned by Kalmaker.
Also the cam is slightly different and the pistons are different (super 6 are coated and 8.5:1 compression) but stock ecotec will work but dont run high boost levels.
Anyways you cam buy my factory cam in a month
slodki
Aug 28 2003, 06:16 PM
Thanks for those replies..
I thought it would be alot of work to fit make it into a factory supercharged V6, but damn, didnt think it'd be that much...
What are the rough price estimates that you guys rekon for making it like a stock supercharged V6, and putting in twin twin GT25's as white lie said??
the[K]id
Aug 28 2003, 06:24 PM
2 options really:
1) Buy a super 6 motor and a few bits from a wrecker, do an engine swap, then a turbo conversion
2) Rip the stock engine apart, put new bits in (pistons, rods if going for heaps of power, cams, etc) upgrade fuel system and then get turbo conversion.
Option 1 would be about 5g + cost of super 6 motor
Option 2 would prolly costover 10g, exact amount depends how much power you aim for.
In the end, prolly cheaper to just buy a VS calais with the super 6, and go from there
Super SS
Aug 28 2003, 09:21 PM
goto
http://www.commsport.com.auThey make turbo kits for all holden v6's
HypoV6 from Summernats has a turbo on his 6 and its based on the commsport kit (although has a few extra goodies)
galapogos01
Aug 29 2003, 11:15 AM
i hope you people who tap into the washer fluid reserviour make sure your mechanics dont fill the bottle with detergent when you get a service... :/
[white lie]
Aug 29 2003, 05:48 PM
HypoV6 has since changed his setup from the Commsport kit and has made a lot more power...the car is also up for sale now too
Super SS
Aug 29 2003, 11:51 PM
galapogos01: Im going to run a seperate bottle for h20 injection, I got the perfect spot to mount it from a pic on another site, right under the power steering fluid bottle
[white lie]: I heard that he has already sold it
[white lie]
Aug 30 2003, 03:15 PM
I think it got sold and the new owner is now selling it...anyway, its up for sale on the S/C forums
Flipmo
Oct 25 2003, 01:09 AM
How about 2 turbos?
one running off each bank feeding into one at the intake, sounds good to me, that would be nice on a 6, something like to t4's,
Marlin
Oct 25 2003, 08:40 PM
That would be a complete and utter waste of time and money as the factory superchargers are pathetic at best may I suggest that you go here "www.capa.com.au" and have a look they have many different kits availible that are far superior to the factory supercharger.
vxterminator
Oct 25 2003, 10:21 PM
dont you mean the rear toyo!
can't believe holden released the super6's with a one legger!
Super SS
Oct 26 2003, 01:59 PM
Marlin: the factory superchargers, while not the best can still be bloody quick.
For example mine runs consistant 13's
superVT
Oct 27 2003, 01:29 PM
the thing with the factory blown 6s .. although the M90 aint exactly the best blower in the world .. is that the engine has been setup to handle a blower .. as opposed to buying an L31 and THEN blowing it .. i'm not quite sure how much boost a factory L31 can handle.
Super SS
Oct 27 2003, 08:40 PM
SuperVT: Don't you mean L36?
superVT
Oct 27 2003, 09:20 PM
haha yeah .. same **** diff smell .
