Apr 9 2008, 10:20 PM
So I decided to do some modifications to the PXA-H701.
I'm not happy with the sound of the stock unit.
This is the work so far on the processor
The service manual is quite different in a lot of resistor and capacitor values from the actual board, although the basic circuit is the same.
Before:
Standard guts of the H701 Processor
Click to view attachmentProcessor Board Removed to show Analog (Right) and power supply (Left)
Click to view attachmentThese little capacitors are all through the processor - yucky
Click to view attachmentSo it was time for some special attention and TLC for the precious analog circuits:
Click to view attachmentReplaced:
JRC4560 opamps with OPA2134.
All electrolytics in signal path with Blackgate Hi-Q NX capacitors
Decoupling electrolytics (3.3uF) with Rubicon XYF, higher values (47uF) to match the manufacturer's specs for the volume control I.C's
Board-mounted RCA sockets with insulated panel mount units.
Added:
100nF polypropylene across the electros
10uF electros + 100nF poly caps on each opamp for improved supply decoupling/stabilising
Removed:
Navi Mix circuit (including 1 opamp stage on front1/front2 outputs)
Click to view attachmentmay think about soon:
Output mute transistors replace with fast switching signal relays
replace Burr Brown PCM1608Y DAC chip with "K-grade" version
The only reasons I'm not doing the DAC now are:
1. won't make much difference in sound
2. SMD is not for fun.
must say though, Alpine have used a very good board for the build - takes a lot of heat to destroy the pads.
Apr 9 2008, 11:49 PM
QUOTE (fury @ Apr 9 2008, 10:10 PM)
Verrrrrrrrrry nice, is the pxa in a listenable condition?
not yet
As far as cost goes, I think I'm up to about $250 so far (including the new DACs) - and that's (almost) enough bits for 2 processors.
edit - this gives an indication of the size of the parts on the PCB
~Spyne~
Apr 10 2008, 08:47 AM
nice work simon - what sort of audible/functional improvements are you hoping to achieve with the pxa mods?
also, have you noticed any improvements, sq-wise, with the roof deadened?
Damo95
Apr 10 2008, 01:12 PM
NICE.... finally, an update..
heard about the PXA changes prior to commencing.. but would be interesting to hear the difference it makes..
good work with the deadening of the roof...
Apr 10 2008, 01:41 PM
It's meant to be lower noise, lower THD, more useable dynamic range, and better resolution of low level signals.
The stock PXA is pretty woeful in those areas, when compared to good Home stuff.
vtviper
Apr 11 2008, 06:46 PM
awesome work! would you be interested in doin the same work to other people's PXA's for a fee?
haha I havent even bought one yet and I'm already thinking of modding it. good work
Apr 11 2008, 08:26 PM
impressive stuff. indeed i hope it translates to 'audible' benefits.
maybe you should do a comparison between modded vs unmodded.
Apr 11 2008, 09:51 PM
QUOTE (shiny_car @ Apr 11 2008, 08:26 PM)
That's the plan - to have it just running straight-through, and A-B compare to my other (still stock) PXA.
Although if the changes are as much as I hope, there should be no problem hearing the difference.
my only real concern is that the evil noise may be introduced by the processor - nothing I can do there... maybe
negatron
Apr 13 2008, 02:16 AM
Awesome work Simon.
I'd be interested if you ever felt like doing these upgrades for my 701 for a fee/
I remember reading somewhere that the weakest part of the 701's chain is the clock?
i'll post the link if i can dig it up again.
Apr 13 2008, 10:54 PM
The clock isn't the best, but replacing it may be a little trickier than usual, as the system uses rising and falling edges of complementary outputs.... have to see once I get this one up and running.
r207
Apr 16 2008, 06:50 AM
id be interested in having my 701 upgraded if you are interested in doing it for a fee.......
Apr 18 2008, 05:34 PM
More updates - nearly done for now, should be working by tonight for initial testing.
Top - now with decoupling caps on I'Cs
Click to view attachmentBottom - also done.
Click to view attachmentjust got to wire the new RCA's and start testing...
sean
Apr 18 2008, 06:29 PM
Nice work
Must have taken ages!
Apr 19 2008, 12:27 AM
About 3 months
Anyways, it's done now:
Click to view attachmentsounds fantastic. No noise, fuller bass, very clean.
Mwahahahaah!!!!!
Apr 19 2008, 12:36 AM
tricky!
Apr 19 2008, 12:40 AM
fury
Apr 19 2008, 01:16 AM
OMG!!!
I wonder if I can switch mine with yours behind your back without you noticing
Apr 19 2008, 07:41 AM
hrmmm....
oh!, wait.............. no.
negatron
Apr 21 2008, 12:05 PM
How good is good simon?
Is it worthy of putting into the home system now?
Hey, wait a tick..
i just realized your're using the optical-in, have you tested to see if your mods have improved the analog in quality too?
I'm interested in reducing the noise floor of the analog in's so i can use my old school transports.
~Sparkles~
Apr 21 2008, 12:36 PM
So was this in use yesterday Simon?
Iceman_jkh
Apr 21 2008, 12:57 PM
Nice work simon.
Good to see someone doing some modding.
Apr 21 2008, 07:57 PM
Yes, it's as good as the home DAC (as far as I can tell without my new amp and speakers running)
haven't checked the analog ins - I think it'll be the same, as I didn't change the input circuits at all.
Kirk - yes, it was running yesterday at the comp.
next mod will be the head unit I think - still a source of noise (poor noise floor hiss - even from the digital output, might be the clock or the power supply)
ReVVoU
Apr 23 2008, 05:43 AM
i have upgrade my pxa too, i am using the same op amp as you. caps are mixed of blackgate nx, elna n sanyo os con for the digital. I have modded the clock as well (reclock using 20ppm crystal) the biggest difference was the reclocking! much smoother sound.
negatron
Apr 23 2008, 10:03 AM
QUOTE (ReVVoU @ Apr 23 2008, 06:43 AM)
HI ReVVoU, welcome to the forum and good to see another 701 modded!
Why don't you post some pics so the rest of us can see how your mods look like.
Apr 23 2008, 07:12 PM
Hi ReVVoU,
It certainly is good to see another modder on here - not too many of us I feel
I am interested in the clock mod - did you have to separate the Dolby clock from the Yamaha chips, as in the circuit they are running off opposite sides of the clock signal (Xtal)???
I have a clock module here ready to go in, but I am wary of that aspect.
vtviper
Apr 23 2008, 10:19 PM
Where do you source these higher quality components? I have an old active crossover I'm using for my system that I wouldn't mind modding up to get a clearer signal.
Apr 24 2008, 06:33 PM
overseas generally.
What I can't get from local distributors (Arrow, Farnell, RS, RPG, etc.) comes from Digikey, Parts Connexion or other places.
mudzuki
Apr 30 2008, 09:13 PM
Very interested in these mods.
Some H701mod pics I found on an Italian site,
http://www.perryhificar.it/tweak/tweak.htm
psycle_1
May 2 2008, 01:49 AM
Any updates on the mods? I'm especially interested in the reclocking mod.
May 3 2008, 09:04 AM
still busy enjoying the sound, and playing with crossovers
The noisy head unit will be the next target, as I am developing now a replacement output stage - completely new board from the DAC to the RCA's.
Preliminary work so far, it will be based on Wolfson WM8740 DAC's and Burr Brown PGA2310 volume control chips. The switching power supply (for DACs and output stage) will be external from the PXA. The clock becomes less relevant as these DACs have much better jitter rejection than the one in the PXA.
psycle_1
May 3 2008, 01:11 PM
Pulse-R,
Did you get my PM re: H701 schematics?
Thanks!
blanketman
May 3 2008, 03:49 PM
where is golf_bht in this disscussion
May 3 2008, 09:30 PM
QUOTE (psycle_1 @ May 3 2008, 01:11 PM)
Pulse-R,
Thanks!
yes, sorry I read it now
The set of circuits are >100MB for the Alpine service manual (Circuit diagrams are A3 and A2 size). bit too much to email. They can be bought from Alpine easy enough on a CD-Rom.
psycle_1
May 7 2008, 06:11 AM
Any idea why there is a pair of opamps for the front 1 and front 2 outputs where as the rear and center/sub outputs only use one?
syd-monster
May 7 2008, 10:45 AM
WOW,...
Greap work everyone. This reminds me that I've forgotten so much about electronics. Excelent results guys. Would love to get back into this.
I used to be set-up for surface mount (digital blower, paste, glues, sucker, removal tools) to do SMT IC's. Stolen now.
Well done & well reseached. (can i suggets you remove all flux resideu, I was tought that it absorbs moisture, but perhaps you have already done that
May 7 2008, 06:29 PM
QUOTE (psycle_1 @ May 7 2008, 06:11 AM)
the extra op-amp stage for front speakers is for the Navi-Mix (GPS) input. now gone.
As part of the same circuit, the centre, sub and rear speakers are reduced in volume by 6dB - gone too
psycle_1
May 8 2008, 02:59 AM
A few questions (I finally obtained the schematic!):
What would be the easiest way to bypass the navi-mix output circuit, could I just solder jumpers from the outputs of the front 1 and front 2 opamps to the outputs of the navi-mix opamps and just remove those opamps?
How do I remove the -6db from the rear, sub, and center outputs?
Last for now, what is your opinion of AD8066 opamps? I'm considering replacing the stock NJM opamps with these.
Thanks for your help!
May 8 2008, 08:40 PM
QUOTE (psycle_1 @ May 8 2008, 02:59 AM)
sorry, I'm a bit slow this week.
That's what I did
remove the transistor Q310, but I looked and it's only for the centre channel - rear and sub are left alone (no navi-attenuate).
no idea on those op-amps, I used OPA2134 because I had some lying around. LM4562 or LME49720 are good too.
TUN35
May 15 2008, 08:35 PM
I should probably get off my ass and look at doing something like this myself!! The noise is driving me insane! lol
TUN35
May 15 2008, 08:52 PM
QUOTE (Pulse-R @ May 3 2008, 09:30 PM)
Also if you like I'm more than happy to host those circuits if you like. Throw me a PM and we can sort something out
12V Hifi
May 15 2008, 10:42 PM
Hi there,
I'm also have this unit on the workbench. I saw some different mods at various websites, nice!
I think you can just drop the whole output section, and connect the DAC (BB PCM1608Y) output to a decent analog output stage. Each channel with his own multiturn volumepot. No remote volume, but all for SQ..
The volumecontrol TC9482 and a lot of C's and opamps less in the signalpath...
Also, two questions:
1.
The powersupply is +/- 9V. The LM4562 is at +/-15V on top of it's performance. Is it possible to change the voltage to +/-15V without "smoke" something..?
2. Service manual please...
Rob.
May 18 2008, 12:21 PM
The +/- supply is only for the vol. control analog section, and the op-amps in the output. so 15V is ok (I have an external converter for modifications.V2)
Also in Mods V2 is the complete re-design of the output stage with PGA2310 volume I.C.'s and possibly changing the DAC to multiple Wolfson parts (depends on what SW mode is used in PCM1608).
12V Hifi
May 19 2008, 04:16 PM
Ok Thanks. I bought a service manual at
www.manuals-in-pdf.com for a PXA-H700.
I wonder the TH9482 is worse then the PGA 2310 volumecontrol..?
Rob.
May 19 2008, 07:42 PM
From what I have heard, the PGA2310/CS3310 is far superior, as the TC9482 changes gain slightly with changes in program level - i.e. is not very linear to changing amplitude signals (such as music) - due to the nature of the silicon resistors inside. The PGA and CS parts have different internal structure of the silicon resistors to combat this problem, with very good linearity across varying signal levels. (more even dynamics).
also the PGA/CS part has internal high performance op-amp, so reducing the need for extra stages of opamps. the total signal path is then DAC->Filter (op-amp)->Volume control->Output. also can remain fully balanced from the DAC to the output for +10dBm balanced outs, and no caps in the signal path
May 19 2008, 11:12 PM
