As title states, I've connected a Pioneer GEX-P5750TVP tv tuner to an AVIC-HD3 headunit using the AV-BUS and IP-BUS cables (IP-BUS goes through a CD-IB100II ipod adaptor). When I select tv on the headunit I get sound, but no picture - just a blank screen. In the manual it says you will get a blank screen if the handbrake is not on. I've tried connecting the green handbrake lockout wires to both the handbrake and directly to earth with no success.
I didn't have an installation manual for the tv tuner and therefore connected up all the wires - including the red power wire. I later found out that the red wire should only be connected if the tv tuner is being used as a stand-alone unit. Could this have done it any damage?
Otherwise, maybe I have dislodged the AV-BUS cable from the headunit while installing it - would this cause the picture to be lost but leave the sound intact?
Any help greatly appreciated.
