QUOTE (abmolech @ Apr 21 2008, 07:41 PM)
Weakest link?
Subjective opinions.
It should be obvious, the weakest link is the car and the install.
Even a cheap home system is able to give most car audio a thrashing in the right room.
The days when electronic differences between equipment made a large audible difference have long since past. (Defective and poor build quality aside)
I disagree somewhat with your assertion that differences in electronic equipment have little effect on perceived sound quality.
My basis for this is my own experience where I have replaced good components with fantastic components in my car processor, and the difference in clarity and resolution is quite clearly audible. The tests I used were; 1. Listening to the modified equipment in my home setup, and comparing with an unmodified piece of the same equipment - in which the improvement of the modified equipment was quite audible in the far field, and 2. replacing the same modified equipment into the car - in which the near field is used, where the differences from the old equipment were quite stunning and easily recognised.
QUOTE (~thematt~ @ Apr 21 2008, 09:47 PM)
And in this world of KISS principles and 100 year old physics laws (only the laws are that young. The actual physics existed since the dawn of time!) there are only three things that affect electrical energy. Capacitance, Inductance and Resistance. Like Abmolech said!!
You forgot magnetism and gravity - or did I miss something?
Audio is a lot more than just electrons whizzing around. You have stated that LCR affects audio, but did not qualify how the effects of these change with amplitude and frequency. The physical construction of a speaker cable will determine its inherent impedance and linearity, which will change somewhat with varying signal levels and frequencies. If the speaker wire is too thin, then you lose clarity and introduce phase anomalies in the tweeters, woofers will suffer from poor damping and "roll off" the bottom end as the resistance becomes too high compared to the amplifier's output impedance.
Thicker wire is better for woofers, but don't go too thin for the tweeters.
QUOTE (VIP318 @ Apr 21 2008, 10:11 PM)
sorry...I didnt realise you were trying to hook up your amps to the battery using speaker wire. my mistake.
Seriously though, as the above have mentioned, there are much, much weaker links (and you are absolutely right about trying to fix the weakest link) than the speaker cable. The reason you might want to upgrade the factory wiring is 'cause the insulation has probably gone all hard, might have been pinched somewhere, not long enough etc etc etc.
I would highy doubt that you would be able to tell me the difference between one side hooked up with factory cable and one side hooked up with ultra expensive wire. Bigger fish to fry and all that
good luck!
Joins, plugs, sockets and thin factory wires will all contribute to degrade the sound quality. most cars' factory wiring is designed by electrical engineers, not audio engineers. It is designed by accountants, not audiophiles.
you don't need to buy the most expensive wire, but as mentioned, 14ga for main speakers and 12ga for subwoofers is adequate.
get the car right with install and you will reap the benefits of better equipment.
