After some advice!
First off I am wondering about getting a kenwood KAC-1023. Its an older model amp (not sure how old) 2 channel, 600 watts per channel, ~1200 watts bridged (this is max power, 600 watts rms bridged at 4 ohm). What feedback can you give me on this? Does it put out what it says, it wont blow up on me (like my boss amp
SPECS:
2 channel amplifier.
300watts RMS and 600watts max while in 2 channel @ 4 ohms.
When run MONO it puts out 600 watts RMS and 1200 watts max. Parallel (speaker cable run + to + ) bridge to mono provides 2 ohms and series ( speaker cable run + to - ) bridge to mono provides 4 ohms.
I believe it is 2 ohm capable aswell, and when running an amp in 2 ohm mode you get more power correct? Is it possible to run my sub in 2 ohm mode while bridging the amp?
I think its a matter of how its wired to change the ohm (a link explaining the ohm would be great!
Thanks for any imput!
Nathan
