QUOTE (khorne @ Apr 29 2008, 12:28 AM)
With all this talk going on about spoons box and his ports wondering what do you all think off mine then as it is built by the same guy that built spoons box it is 3.7cuft and has 2x6" ports and tuned to 54hz, i have a epsilon ea5000d at 0.5ohm providing the kick, this is run in a n14 pulsar hatch and a best score to date of 142.5db. i plan to up the hz to 65hz and 45hz to see if either is any better, i need to flare the ports aswell and brace the box.
It's too big and tuned too high.
I'd go 2 cubes net or smaller, build the box so you can move the end wall to change the volume for testing.
You very rarely need to tune higher than 45Hz in that type of car, as they tend to hit around 54-56Hz.
