- Stroked to 4.2L
-aftermarket ultra light flywheel
- Bored & polished head
- C.O.M.E Racing manifold
- composite manifold insulator
- increased compression ratio
- aftermarket "Crow" cam +
- Aftermarket chip tuned to max safe power on Premium 8000
- Oversized bored out + polished throttle body
- Bosch hi flow long body injectors
- bosch twin knock sensors
- bosch hi flow fuel pump
- Bosch hi flow fuel filter
- FIT rockers and tips
- FIT 81°C cooler thermo.
- MSD spark leads & NGK Iridium spark plugs
- SS intake + 2x K&N podfilters on 4" custom Y piece stainless steel pipe. (one located on left side bumper, other heatshielded in engine bay)
-heavy duty clutch & pressure plate
- Pedders shocks and suspension.
- exhaust system made to suit perfect back pressure:pacemaker extractors -> 2.7"->lukey hi flow cat->2.7">lukey hi flow muffler-> tip
- it has a
- VY SS LSD modded diff
There are probably more things done to it that I have no clue about. Dude at the performance shop reckons it should be easily pushing out around the 200kw mark. Beating S15's, Skylines and even a manual XR6 turbo and a VY SS 5.7L, to me is sorta believable. Just wanna see what you guys reckon it does with those mods before I dyno it in a few weeks.
Cheers guys.
edit: added a few mods I missed to mention!!
