Full Version: Computer Based RTA, How to interpret?
Pages: 1, 2
BMWTurbo
Hi Guys,
For interests sake I had a play with jDFT last night, connected to my laptop through the 'mic in' and with some test discs.
http://www.e.kth.se/~johk/jdft/download.html
I've been playing around a bit with the Eclipse E-iserv, which through connection of a supplied mic, the eclipse unit will take a Data file reading inside the car through internally generated pink noise and will save it to a memory stick to interface with the E-iserv website for some auto-EQing. You can set this to for 'low/mid/high'n'low emhpasis and it will set the parametric EQ's to suit.
In short I connected the Eclipse RCA mic through to the mic in on the laptop and ran the pink noise to get an idea of what the response in the car was like. As other people have mentioned previously I also found dips around 400hz, 800hz and around the miw/tweet crossover point.
Has anyone else played with tools similar to this? I can't calibrate the level easily to show true 'dB' levels etc so all I'm seeing is a relative comparison accross the range, the dips might be 1dB they might be 10dB. I'm not really sure what to make of this.
How are people interpreting the data from such programs?
If there are similar threads I can't find them and would appreciate be pointed in the right direction.
Ben
MatS
I use the true-rta sortware, behringer ECM8000 mic and a Lexicon LAMBDA as an interface/phantom power for the mic. Software is easy to use and allows for mic calibration (which is easy to come by for the ECM8000).
http://www.trueaudio.com/
I'll try put up some screen shots when I get home of my results/interpretion from a previous install. Very easy program to use and fairly popular.
BMWTurbo
Cheers MatS, I've got the free version of TruRTA and had a play with that also. Seemed to be a good program, and with the ECM8000 you can jsut download the cal file from what I could see for it.
It appears that the jDFT can be adjusted to read correctly, I'm a little confused as to how to accurately do this, I do have some tracks on my test disc's that drop in steps from 1-3-10dB, which might be useful in adjsuting this.
How do you find the response when you run pink noise through the system? Do you end up with a smooth lookibf curve or very peaky?
I seem to get large fluctuations when the timing is set to read fast, I didn't realise I could smooth this out until playing with it today, so I'll play with is a bit more tonight.
using a swept sinewave is a better method for testing RTA in a car.
The problems with pink noise are based around reflections and time alignment issues which can mask the real response.
i.e. if a reflection is nearly as strong as the main signal, but a short time later, it will cancel out the original sound, creating a dip in the RTA, but our brain knows it's late and ignores it - so the RTA shows a dip which is not there. same with time-alignment and crossover issues.
A swept sine measurement is a 'moving' slice of response time, so by the time that reflected (or otherwise late) sound arrives to try and cancel out your reading, the RTA has moved on in the frequency band, and the peaks and dips no longer interfere with the instantaneous measurement.
look here for more info:
http://pcfarina.eng.unipr.it/Public/Papers/134-AES00.PDF
BMWTurbo
QUOTE (Pulse-R @ May 3 2008, 08:25 AM) *
Thanks Pulse-R. I'll print it out and have a good read of it smile.gif I've been thinking about it and shoudl probably use a 'peak' reading also as a better indication.
Reflections etc would have been causing the odd lulls etc that I was seeing on the screen when running pink noise, hopefully I'll be able to screen shot etc also, in order to get an idea of what crossover curves etc are doing to the response of each driver.
Should have some gear on it's way to me soon in order to investigate further.
SCorpion
QUOTE (Pulse-R @ May 3 2008, 08:55 AM) *
mad link.
what gear do u use to measure response? im looking to do a lot more measuring of in car response to see if i can absolutely isolate the issues im having with. u've already heard the issue im having. i want to be able to do more than just guess at what is going wrong with my setup.
BMWTurbo
It seems it's generally recommended using a Behringer ECM8000 mic with a suitable powered mixer feeding into a soundcard on the PC.
SCorpion
QUOTE (BMWTurbo @ May 13 2008, 04:03 PM) *
ok, so wat is a suitable powerd mixer to feed into a soundcard? and wat software should i use on the PC? would $500 be enough for a reasonable setup to be used in car?
MatS
http://www.mobileelectronics.com.au/forums...howtopic=540661
good setup I'm lead to believe
I use a behringer ECM8000 mic and a Lexicon LAMBDA (USB interface) with TrueRTA software
BMWTurbo
I'm by no means any expert, I'm trying to get my head around it atm in order to get a system up and running.
I'd hazard a guess and say that if you have a suitable laptop already $500 should be more then enough to get you happening.
From my searching the site below seems to have reasonably priced mic's and mixers. Obviously you are going to need some cables and perhaps a mic stand to tie it all together and also connect to the line in/mic port on your soundcard. Behringer ECM8000 mic and the 802 powered mixer.
<a href="http://undergroundmusic.com.au/index.php?m...amp;keyword=802" target="_blank">http://undergroundmusic.com.au/index.php?m...amp;keyword=802</a>
The software, I'm not up to speed on yet, but it appears there are some okay free programs that will work for the basics, but if you want to get more in depth you might have to 'purchase' a more advanced version.
I don't think http://www.mobileelectronics.com.au/forums...howtopic=540661 is available anymore;)
Whilst its not the be-all, end-all, have a look at this thread to get started....
http://www.diymobileaudio.com/forum/showthread.php?t=1
and this one for some hints and direction on testing
http://www.diymobileaudio.com/forum/showth...ighlight=preamp
Ran whole scenario thru computer and comptuer said...
NO
lol
SCorpion
http://www.hometheatershack.com/roomeq/
i was thinking of using this. they have a pretty active forum with lots of ppl with lots of knowledge so i can at least get started. they have lots of support such as a calibration file for the ECM8000. it all looks pretty good actually!!
BMWTurbo
I did some playing last night with jDFT and the little mic that came with my Eclipse head unit and after sweeping a few times, I could slearly see some dips, that I managed to bring back a bit with the para EQ's.
First impression is it's sounding better. Will have to spend some more time with it though.
Another cool thing I played with was changing crossover slopes and cut off points and watching the response. This has allowed me just by moving the sub from 63 LP to 80LP to get almost flat (relatively) from 20-350hz smile.gif Whereas I'd previously thought I had a bit too much upper bass, it appears it's well balanced 'on the screen anyways' tongue.gif
My only wish now is that I had seperate right and left channel EQ. I've read about great results with being able to EQ left and right channels independantely, by cutting one side and adding the same to the other, in order to shift the image to the centre, but not affect the overall level of the particular frequency.
Matt VIP
QUOTE (BMWTurbo @ May 14 2008, 10:17 AM) *
can you point me in the direction of that reading?
I've done that before with my P90. Never heard a sharper image then that setup, by far. Tonality was off, but image was incredible.
BMWTurbo
QUOTE (VIP318 @ May 15 2008, 12:44 PM) *
Sorry I can't find the thread anymore, it's on the DIYMA forum.
Using these things can be very addictive tongue.gif I've played around with EQ etc and am amazed how much relfection etc really affects the response at your head location.
When the mic is placed in front of each driver on a sweep I get VERY linear and smooth response, when you sweep with the mic in the 'head' location the response turns to crab. I think it's a mixture of the low quality mic and the jDFT softwre, but it's tricky to tune it to anywhere near ressembling a flat response.
I have found you need to be very precise with the mic location to and small changes hear can drastically affect the results.
BMWTurbo
Spent some more time with this last night using my newly acquired ECM8000/UB802 combo and am getting some differeing results.
I'm still waiting on the trial licence for WinMLS so have been using jDFT to do my measurements, but am not happy it's providing the desired information accurately.
I set a single mic up in the location of the centre of my head (midway between both ears in the listening position) and was using a 20hz-20Khz sweep (Track 60-62) on MY DISC. I didn't manage to get any screenshots as my laptop died before I got a chance to get my head fully around the results, but when turning the 'Pink 2 flat' and 'hold' functions on using an Inertia of 12, length of 93 and 'hanning' I found the dips I knew were there.
I set about using the PEQ to get rid of the dips and managed to get the curve fairly straight, but for some reason, it always swept up on a fairly straight line, from 20-18k(where it slightly fell off). This suprised me a bit as I was expecting to see a fairly horizontal line, with some peaks and dips along the way, no so much an increase from low to high.
I tried the same thing, with the PEQ set and 'pink 2 flat' turned off and I got almost a perfectly flat line pretty much accross the board. I was more then happy with this until I tried the same sweep at a different volume level and seemed to get around the same level indicated on the screen, I even tried a sweep where I vaired the volume a large amount through the sweep and ended up with a flat line also.
I'm at a bit of a loss as to what to make of this. I was expecting to see variance in levels shown, but was not expecting the whole response curve to rise in almost a straight line from low to high.
Has anyone spent any time with this and seen similar results??? I'll be hunting down the ECM8000 response curve today to see if there's something funny going on with an increase in sensitivity as you move up the freq spectrum.
*EDIT* I've found a cal file for the mic, it appears 'to be down 3dB at 20Hz and 9dB at 20KHz' . I'm assuming this is a roll-off, but doesn't really explain what I was experiencing.
Slightly conflicting info here.... http://personal.inet.fi/private/ilkka/Behr...corrections.txt
using a stereo pair of mic's helps to 'average out' the measurement over two locations, i.e. one for each ear.
the dummy head is best, but expensive.
measure left and right separately, and then both together - lots different results due to reflections and cancellation.
also, when you measure the left side, open all the doors on the right side, and vice-versa, to help eliminate late reflections.
BMWTurbo
I did some more testing last night with both mic's, but summed there response rather then using L & R. One thing I did notice was peaks and dips of up to approx 3dB variance fromt left to right mics, when they were set up facing slightly outwards, about a head width apart.
I also started off with a single mic, placed in left ear, centre head and right ear locations and noticed variances accross the board.
I also noticed slightly more bass level with the left/centre mic when compared to the right mic.
I must admit I'm not sure if I'm going fowards or backwards after testing/tuning as now it seems I'm far from happy with the indicated response tongue.gif Sometimes you can have too many things to play with...
I haven't set about testing left and right channels independantly yet as I don't have any independant L/R eq adjustment. I have also tried to limit the amount of EQ added, by pulling out of peaks and adding to dips, to try and smooth out the response, rather then adding lots to dips.
By the end of 'tuning' I ended up with a response curve that was a couple of dB higher at the low end and gently tapered down to the high end until about 17k, where response seemed to roll off.
Click to view attachment
You can see this was the first set with a single mic, in the left/right ear positino and centre of the head, no EQ applied. I didn't save the final curve however, it was much flatter and refined.
BMWTurbo
Well I got my trial key for WinMS late last week and managed to have a play around with it friday night.
I first started with a single mic in the centre of the head (read midway between where my ears would be) and ran the impulse response for each individual speaker. I've read somewhere that this is best done with your time alignment set at zero, but I was curious to see how my 'by ear' settings fared.
I ran the impulse through each speaker and overlayed them on the one graph. To my suprise/delight I found that I had phase and TA set perfectly for each speaker in the system. There was a slight 0.02ms difference between left and right tweeters, but I couldn't get this any closer as my HU only has 0.1ms gradation. That seemed easy.
Next I did the freq response of each speakers running no crossovers, to get an idea of what range they'd play to. I didn't get jpg's of this, but the tweeters played cleanly to around 1k, the mids played from about 60 ish up to 3.5k ( I think they had some slight breakup up high), and the sub would play from about 150 down.
Crossover points were set slightly different from previously, in the I used a slightly less slope on the mid in order to raise the 1250hz response to save an eq channel. I ended up with:-
Tweeter :- 1250hz-18dB HP
Mid :- 63hz-24dB HP <-> 1250hz-18dB LP
Sub:- 80hz-24dB LP
I managed to tune out some system install deficits in the 400hz, 800hz, and high region, but to be honest, with the 'flat' (term used loosely) curve you see the system sounded very average. I pulled back some of the sharper EQ's by ear and have the system sounded much smoother to the ear.
As I've mentioned previously I found it very interesting that when the mic is placed in front of the individual speakers the response curve's are smooth and reasonably flat, it's really highlight to me how critical angles on the install are. I when moving the mic off-axis from the mids up towards the angle you are listeninng at, you can clearly see the 400 and 800hz response drop off as you move off-axis. Unfortunately I don't have the room in the kicks to mount the mids anywhere near on-axis, without interferning with gloveboxs and pedals, so I'll have to live with it, or change toa 3-way system with a midrange that will play to 350hz tongue.gif
Anyways, a pretty picture, showing, before LH/RH/Summed and after :-
LHS is the LH mid/tweeter
RHS is teh RH mid/tweeter
PEQ 5 is my 'flat' setting
PEQ 4 is with the mids set as above, but the tweeter pulled back to run no EQ
All levels, TA and crossover points were set the same, the only changes are in the EQ
I haven't got a response curve with my 'tweaked' settings, but will fire the gear up again one night this week and get some curves.
kittan
I use a Behringer ECM8000, M-Audio Mobile PreUSB for the phantom power,preamp and soundcard.
For software i use TrueRTA for its soundcard and mic callubration purposes when RTA'ing.
I use ARTA to adjust time delay...
Attached is my response graph. Last i did was took -2db at 100hz to correct that last spike.
BMWTurbo
How do you find the sounds when running flat? What was th response like prior to EQing? *Edit* Stumbled across your DIYMA thread smile.gif
I found I preferred the highs pulled back slighty and much prefered a slight increase in bass/midbass over the midrange/high frequencies.
Nothing like a really nice kick in the midbass.
Just found some data I saved from when I measured each speakers response w/o crossovers. You can also see the impulse response in the bottom graph with the measurement being the initial dip, ie maximum difference of 0.07ms, which in analysing is slightly more then I'd said previously, so I could potentially take 0.1ms out of this tweeter, though it would then hit my ears just before the LH Mid.
can you expand the graphs to show a smaller range, i.e. 70-91 dB, to show better the -3dB points, and the roll-off.
That 110dB scale is hurting my head
BMWTurbo
Hey you go Pulse-R...
nasty dips !
(300Hz to 1kHz) and 2.5kHz - is that car troubles?
BMWTurbo
Keep in mind that graph isn't calibrated, so 10dB on the scale more then likely doesn't = 10dB in reality.
The measurements were taken with a single mic at teh mid point of the ear's in listening position. I found the response changed when you moved the mic to each ears location and again when I used both mics( one in each ears location) and summed them.
I have also only applied light smoothing to the graphs, so this doesn't help.
Tweeters in pods firing at screen and Mids in kicks vertical.
I think the 300-1kz is due to enclosure of the mid's they are in the kicks with a tile of acoustic foam directly behind them, ie small enclosure. It's more so a hump at 90-250 ish.
The 2.5k dip appears worse in that plot then it actually is.
BMWTurbo
To add further on my experiences, I spent some more time with this last week/weekend and don't believe that I'm interpreting the data correctly.
I took roughly 100 sweeps, one after the other with the microphones in slightly ie 5mm intervals differente locations and the response curves varied heavily. I was seeing +6dB on previous measurements not 5mm from the previous location of the mic.
I will need to read up on the software and come up with some settings so that I'll be able to get some usefull data from the 'rig'.
I'm also annoying limited with my EQ in that I can't do L and R independantly, which drives me nuts trying to come up with a nice medium between the LH and RH channels. In the end I set all speakers running and got the curve as close to 'flat' as I could. I then tuned it by ear, adding and removing in order to get a good tonality accross a variety of different music styles.
BMWTurbo
Talking amongst myself again, I found it extremely interesting the differing response curves encountered, with someone sitting in the vehicle, and not being inside.
I did the exact same test twice, once with me sitting in the passenger seat, and another time with me outside the vehicle. I also did a test with the mic directly in front of the driver near the trans tunnel to get an idea of what the direct response was like. This isn't calibrated as such, so a shown 10dB dip/peak might in fact be 8 or 12dB... I haven't had a chance to calibrate it accurately, but it clearly shows responses and thier differences.
Another reason to "tune" the system with similar conditions to judging - i.e. 2 people in the car.
although I'd say you need a bit more angle on those woofers to get the dip out of the upper end, to stop them firing into the footwell so much.
BMWTurbo
QUOTE (Pulse-R @ Jun 8 2008, 01:03 PM) *
That is obviously the best way to do it to try and get as much 'usefull' data as you can. I'm probably just regurgitating commonly known information/effects, but it becomes blindingly obvious when you start donig the testing etc yourself.
I'm trying to arrange a spare set of kick panels, so I can start again at the front, I'm still not convinced that I'll get enough angle to get rid of the 'nulls' and to be honest I wasn't aware of these when listening to the system without the test data to highlight the areas that could do with some work.
Another solution might be to add a dedicated midrange on the dash, this will require another amp though and I'm not really sure I want to go through all that effort... I really like the simplicity of the system in it's current state smile.gif
I persisted for 4 years until I saw the light - of sound.
now I spend more time listening, and less time looking, at the sound
SCorpion
QUOTE (Pulse-R @ Jun 8 2008, 10:53 PM) *
thats curious. i believed the same, but my uncle (and others) have pushed me hard into getting setup with proper measuring gear. most of those guys have been building/designing speakers for 20 or 30 yrs. the ear is good for telling u if htere is a problem, but the science to back it up removes a lot more of the guesswork to
yeah, I suppose - but, in terms of success I have found my ears lie less than the numbers.
SCorpion
QUOTE (Pulse-R @ Jun 8 2008, 10:59 PM) *
the ears are always the difinitive measuring tool. after all, i dont think anyone fully understand's how the brain works particularly where it rejects or even interpolates musical information. but in saying that, just relying on ones ears is using more guesswork than with using some measured data. the most experienced listeners that i know, all use a mixture of measured data, theoretical knowledge and experience.
im learning the first two, but the third one is still a long long way off laugh.gif
it also raises curious commercial implications to. does a manufacturer build the best specs based system and just release it into the wild, or does he build the best specs based system he can, spend months getting as many ppl to listen to it then release it into the wild? all very philosophical of course laugh.gif
its very interesting that, even for an audio site, that the general MEA approach is very subjective. it seems that anyone who tries to use theory (be it right or wrong) gets shot down. take stereonet for example, lots of theory is bandied around, but everyone there still appreciates that the ears are our best measuring tool.
anyway, just my observations.
same same - use the theory and measurements for basic design, then the ears to perfect the implementation.
no point having a perfect measuring system if it sounds dry and dead.
SCorpion
QUOTE (Pulse-R @ Jun 9 2008, 09:34 AM) *
BMWTurbo
I'm using it as a tool. As mentioned I've found that I wasn't impressed at all with the way the stereo sounded when I had it 'somewhere' near flat on the RTA, so this was then tuned by ear and retested and it was suprising what sounded nicer to 'my' ear was a fair way off what the RIG was suggesting.
I spent a little time with the CRO today, testing the HU's output and amp outputs to check for the inset of clipping etc.
I was getting a deviation in sound on some tight bass notes at high level and I wanted to decipher what the cause was. It sounded like the sub might be bottoming out, but being the w15GTi, it shouldn't be able to. Testing pures tomes showed that I was getting a distorted peak from the amp output just after hte onset of the noise I was trying to source.
It wasn't clipping in a strict sense the top of the peak went from a clean sinze shape to a sine shape with a fuzzy peak section. I had kind of expected to see a clean truncation of the signal, but this wasn't the case.
Fearing HU distortion, I tapped into the RCA feed and found that even on max volume I was getting clean signal out from the HU, so this wasn't an issue.
The amp was simply running out of puff.. I need more power... Aparently the 750WRMS odd that I'm feeding the JBL in IB is not sufficient.
As a further test I measured the front stage outputs also, and found using 440hz, 1000hz, and 5k tones that I wasn't getting any clipping etc, even up around 74/80 on the eclipse HU, the sub started to show signs of stress in the song in question at roughly 66/80.
Without testing etc, there would have been no way I could have accurately diagnosed this issue, slightly different to SQ as it's not 'as' subjective, but theory/testing definitely will keep a strong place in my 'tuning/diagnostic' regime.
also remember that the amp's power supply will often run out sooner - perhaps this is one case where a cap might help. If you have one, try it and see the difference.
or get an amp with a bit more headroom.
BMWTurbo
Can you elaborate pulse-r?
The sub amp is a DA7122 Eclipse, apparently rated at 1000WRMS into 2ohm mono load. I'm only running the amp at 3ohms from the bridged coils of the w15GTi, so I'd be suprised if the amps power supply was an issue?
Are you referring to the battery? I have a 1050CCA calcium matrix battery and it's only feeding the PA5244 and DA7122 Amps. I'm running a 4-gauge to the DA7122, approx 2m run, both the postive and negative are connected at the battery. The PA5422 has four runs of 8-gauge, approx 3m long, twin pos and neg runs again to the battery.
I have an Eclipse DA6213 2x250WRMS 2-channel that I can try running the sub it's not 2ohm mono rated but being a nice big D-class amp, I would expect it could cope with running 3ohm mono with music. This was going to be my next option, other then that, I'll be needing something that will deliver 1200RMS+ clean power into a 3ohm load to keep up with the front stage.
PMG
Hi Gents. good thread and well-reasoned posts. Have been using RTAs to verify system linearity (electrical and acoustical) for a very long time and still use one or t'other here to check what I think I'm hearing. Apart from a big B&K unit I was surprised to find that one of the most practical RTAs I ever used was built-in to the first AlpineF#1Status processor (PXA-H900?). You could adjust and see the effect for each mic location in real, real time!
But I have to totally agree with Pulse-R - pulse response measurement can provide more accurate data (after countless hours trying umpteen mic locations and cabin configurations to reduce standing waves etc.). And also re using your ears... we must remember an RTA is typically 'reading' a cabin with a microphone that is only a rough facsimile of the human ear, plus plots are typically created in a stationary vehicle which doesn't reflect real world.
I suspect that the countless PC measurement systems around are good fun to waffle about and use, but you will find few of these actually used by real engineers. I also believe that most still find it better to tune to an 'equal loudness contour' and to simply time-align so that like sounds are relatively phase-coherent. Or is that just fading memory on my part?
In other words, I suggest you don't get too hung up on measurements in your search for in-car sonic perfection. Get the speaker 'loadings' right first and the rest kinda falls into place.
Kind regards,
have to agree - if you get the phase response right, the rest comes as preference rather than correctness adjustment.
but 'preferring' a 'correct' sound is also a learning curve.
as to the amp problems, Ben:
if the waveform is getting furry, but not flat-topping then that is usually a sign that the filter caps in the amp's power supply are havign trouble keeping up with the load.
another suggestion is to try a more efficient woofer/box combo.
SCorpion
QUOTE (PMG @ Jun 11 2008, 05:43 PM) *
i disagree. every speaker manufacturer and amp designer i've ever spoke to all use measurements as part of their design philosophy/process.
i think it is very easy to get sidetracked by measurements, but i think it is even easier to get sidetracked by going by 'ear' alone. maybe its just my influences, but measurements play a fundamental role in predicting a systems response. it is something im going to get into heavily once i have the dosh.
another thing i notice (on these forums) is that ppl always say, get ur speaker placement right first, then everything falls into place. that doesn't make any sense. how can u be sure that the placement u have is right without taking any measurements? guys with 20 or 30 yrs experience all tend to be able to get the speaker placement right by ear, but they are always confirming that what they have is indeed correct.
am i just old school?
BMWTurbo
I think unless you have goldens ears, you will come to a point where you will want to 'know' what is happening as well as what you actually hear. Obviously what measures and what is heard can vary due to a mixture of drivers, enclosures, location, environment, processors etc.
I think that tuning with equipment can give you a very good base in a few hours work, that could potentially take months/years to perfect if you are rellying ion your ears only, for the average enthusiast.
PMG
Apologies SCorpion, you're right of course - I was actually referring to those 'freebie' download programs mentioned earlier rather than the proper measurement systems such as Klippel, LMS etc. which ARE used by genuine engineers. Sorry for confusion.
My apologies for sounding arrogant here too, but with common-sense and a shed-load of custom work (plus some understanding of cabin acoustics and a reasonable ear admittedly) I think you can get a remarkably good sound-stage in most vehicles. But I agree, being able to verify and fine-tune your choices is the icing on the cake, and I'm not dismissing it on any level. As I said, I use RTAs regularly to do cars and boxes but I also trust my old ears.
As for 'golden ears' - is there really such an animal (like reviewers who claim that factory systems sound good, many seem to self-annointed morons in my humble experience)? BTW, if any of you need brief access to an RTA, perhaps shoot me a PM - I may not always be able to help here, but should be able to point you in right direction. Kind regards,
SCorpion
QUOTE (PMG @ Jun 16 2008, 12:50 PM) *
i wholeheartedly agree with wat u have posted above good.gif (you dont sound arrogant by any stretch of the imagination by the way)
there are a few reasons some of us have *a reasonable ear admittedly*...not golden ears etc but an ability to cut to the chase audio wise.
Its using RTA's etc to find out why what we hear looks like, and why, what looks good on an rta, isnt the real deal...experience is what its about.
The ability to interpret an rta or what you hear is a skill that takes time to learn and isnt something you can learn via a book or lisitening to same bad sounding stuff over and over. You need to experiment and work out why whats good is good.
You don't need golden ears to appreciate a good system, but you do need experience to know how to make an OK system sound better...its not about the RTA its about knowing what the RTA means to the result, in real world...forget the specs and just listen.
*measure's good, sound's bad, means your measuring wrong thing*
BMWTurbo
I agree with all of the above. I often get caught up on little tangents such as trying to get resposne curves dead flat etc, but as mentioned I've 'tuned' for flat and then retuned by ear, and ended up not far from where I was originally starting from tongue.gif
It really is a big roundabout, spend time tuning (aiming for flat), then spend more time tuning by ear, which in turn seems to 'undo' the previous efforts tongue.gif
The only way to determine how best to interpret results is to spend the time aiming for a particular target, and then reassessing the results. Unfortunately I only have one or two systems to play with, so I'll be limited with my findings based on my ear and my test measurements. If I can overcome the level matching issue I have, I should also be able to get some form of repeatability of testing. As it stands now due to changing gains etc to try and set it up accurately, my graphs arguably can't be directly compared to one another, unless they were taken in the same 'set' of measurements.
Hopefully I should be able to come up with a few tuning guidelines, that I will effectively be able to use in order to quickly get a system to near where I want it and then let the ear do the rest.
PMG
Just a quick point about response curve targets. The only time I ever look for 'flat' is when measuring the output of electronic components. But acoustically, especially in a car where the masking effect of road-noise 'absorbs' a huge amount of LF response, I tend to target an 'equal loudness contour', sometimes called the Fletcher-Munson curves. This is pretty much the inverse of human hearing sensitivity at various loudness levels (I use around 90dB). Probably why the OEMs get it so wrong too - flat tends to be very boring.
zion187reigneth
ive had the same problem when ever i used active setups.Im trying to make my gain pots similar in using similar amps or atleast try for the same amps.
Using 3 different volume level settings i have tweaked the gains and used the -30 volume adjustments found in the eclipse 8455 time alignment folder to tweak even further.
In short i have discouvered my ears cannot tune systems ,if i ever enter SQ comps again ill have a sticker on the window saying who tuned the thing.
